Post by rockyraccoon on May 1, 2007 11:39:12 GMT -5
this is one for spirit stone. he provided the stones. i've never seen ammolite in person until this and it is just awesome. made me really want some until i went and looked at the cost ;D. kim sorry about the coin behind it. i didn't see that until now.
adrian65
Member since February 2007
Post by adrian65 on May 1, 2007 12:03:09 GMT -5
Superb stone that ammolite. Looks like sort of opal. The wrap is also gorgeous.
Adrian
cleo12797
Member since April 2007
Post by cleo12797 on May 1, 2007 12:51:11 GMT -5
That stone is amazing! Great wrap! I'm afraid to even look into the cost of the stone.
Ang
nancyf
Wired Cowgirl
Post by nancyf on May 1, 2007 14:46:51 GMT -5
Fabulous cab and wrap! Yep...I've never bought ammolite either...I've bid on some on feebay, but never won one. sigh....
jjckitti
Member since January 2007
Post by jjckitti on May 1, 2007 15:33:32 GMT -5
amazing stone... and even more amazing wrap. great job Kim. very elegent and flowing.
Post by Jurrasic Jonje on May 1, 2007 15:37:19 GMT -5
Great looking wrap. Ammolite is really cool. Silverhawk has 2 on his site and they are both over $200. Glad to see a kim wrap again.
Post by goldfinger on May 1, 2007 15:48:49 GMT -5
Wow Great work.!!! Is that particular wire wrapping design yours or did you learn that from someplace else? I have some square cabs that might look good in that design. Great job regardless Steve
Post by Cher on May 1, 2007 17:27:04 GMT -5
Ooooooooooo Kim, that is stunning!! Beautiful stone, you enhanced it perfectly.
Post by Tweetiepy on May 1, 2007 17:42:39 GMT -5
beautiful stuff looks like the sparkly stuff in opals or the stuff that peaks out of boulder opals! Great wrap too!
What's the circular shell called I thought that was an ammolite?
Post by larrywyland3 on May 1, 2007 19:42:52 GMT -5
WOW You did an awesome job. You definitely have a gift for doing the wrapping. When I saw the pics of wraps you had done; I was hoping you would do some of my cabs and ammolite freeforms. Thank you for agreeing to do them. Great job photoing the finished pendant. The ammolite can be very difficult to photograph.
Post by larrywyland3 on May 1, 2007 20:07:13 GMT -5
Tweetiepy, the circular shell is the nautilus; it is the modern day descendant of the ammonite. The squid and the octopus are also descended from the ammonite. The gem ammolite comes from ammonites that lived in the Bear Paw Sea. It was located in what is now Alberta Canada. The Bear Paw Sea was cut off from the rest of the ocean and the ammonites there grew to be much larger than in the rest of the world. In addition the Rocky Mountains were volcanically active and dumped a lot of mineral rich ash over the dead ammonites. This along with some geological events transformed and preserved the argonite (mother of pearl part of the shell same stuff that makes up pearls) The preserved shell can be up to several mm thick (before being worked up). Fossilized ammonites from other places in the world only have a paper thin shell layer left or none at all. Also, red and green are the only colors seen in other fossilized ammonites. For those reasons only Alberta fossilized ammonites are called ammolite. Some ammolite is also found in northern Montana, but they came from the same Bear Paw Sea ammolites. I really like the gem (as if you couldn't tell ;D), but it is now more expensive than I can afford. But I can still blab away about for free LOL.
Oh (here I go blabbing on again), the colors are from iridescence which is the effect of light passing through the layers of the preserved shell. Which is different then light reflected out of a gemstone. In some ammolites if you change the direction of view you get a different color. The one Kim did, if you turn it upside down it will look more brown. Kim did a great job get the gem to show its best colors. In the case of this gem the color is directional and is not considered a color changer. If it were to go from green to red then it would be a color changer and not consider to be color directional. The color changers are much more rare only about 5 to 10% of all found. About 50% found are considered hand samples not really intended for jewelry. the next 25% are the color directional gem grade. The Last 25% are a near infinite combination of colors, patterns and color shifts.
Post by Bikerrandy on May 1, 2007 21:17:29 GMT -5
I'm not sure that I know that much info on anything. ;D Seriously, that's all quite interesting. That's a beautiful stone, and Kim did an awesome job as usual!!
Post by rocklicker on May 2, 2007 2:21:08 GMT -5
Wow! Simply stunning. That wrap looks so elegant and flowing. I like the loop on the side. That stone is cool too. Steve
LastsGal
Member since March 2007
Post by LastsGal on May 5, 2007 20:42:49 GMT -5
Wow! I absolutely love that stone! Beautiful job on the wrap, too!
Post by Jack ( Yorkshire) on May 6, 2007 1:36:15 GMT -5
Hi Kim, A real good job on that Ammolite it is so beautifull as someone has said just like opal
You got the raps so close and well spaced a excelent wrap thanks for showing
Jack Yorkshire UK
Post by creativeminded on May 7, 2007 8:46:44 GMT -5
That is a georgous stone, and you wrapped it well. Tami
