LastsGal
Member since March 2007
Post by LastsGal on May 2, 2007 20:19:57 GMT -5
New earring wraps that were a true team effort. Robert cut some slabs out of his bigger rocks, I cut the shapes with the trim saw & made my first cabs with the grind wheel. That was (very!!) fun! Then he took them back to tumble, after which I wrapped them. You guys are right... the smaller the stone, the bigger the pain! The first is labrodite and the second is silver crazy lace.
Post by beefjello on May 2, 2007 21:13:08 GMT -5
Very nice! You two make a great team!
adrian65
Member since February 2007
Post by adrian65 on May 2, 2007 23:18:58 GMT -5
Excellent! You're becoming an earrings specialist!
Adrian
jjckitti
Member since January 2007
Post by jjckitti on May 3, 2007 16:12:56 GMT -5
the earrings are coming out great! love it.
nancyf
Wired Cowgirl
Member since April 2007
Post by nancyf on May 3, 2007 19:12:06 GMT -5
Yep...small is harder...you might want to try half-hard wire in 22 gauge ( 21 could pass also)...try and take quilting tape and go around your stone...mark on the tape where you want to bind the wires. This type of tape is thin and much like masking tape...easy to use. Anywho, it will put those bindings in just the right place. Also, half-hard wire will give crisper bends and for the style you are implementing not a problem to work with.
Ya'll did good for sure...earrings are a real pain. ack!!! I adore those stones!!!!!!
If ya need any help at all with anything...just email me. No problemo!
Post by rocklicker on May 4, 2007 1:05:09 GMT -5
Nice work! I like them both. Cool that you cabbed them yourself. Just be careful. It can be VERY adicting. Pretty soon Robert will have to wait for the cabbing machine.
Here's another tape suggestion (I love using tape). Get some drafter's tape. It's the same thing as masking tape but smaller and comes in a tape dispenser so it's easy to use. Being that it's 5/8 in wide, you take an exacto knife, remove it from it's dispenser, and VERY CAREFULLY cut two parallel lines all the way around as deep as you can safely. You cut them so you have three 1/4"-ish lines of tape. Then you put it back in the dispenser and use one strip at a time. It's nice and thin and not too sticky. I hope that makes sense. Steve
Silver Lass
diagonally parked in a parallel universe!
Post by Silver Lass on May 4, 2007 7:42:58 GMT -5
I love the earring they are just beautiful. Dorothy
nancyf
Wired Cowgirl
Post by nancyf on May 4, 2007 8:40:17 GMT -5
Hey Steve! I'm a tape nut too! The quilters tape is already 1/4" wide (or less)...you can also get it with lines on it like a ruler...I use the blank though. For holding wires, I use auto paint tape...it doesn't goo like some other tapes do. ack! Oh well, the tumbling gets it all off. Anywho, I think tape is one of my most useful tools.
Post by rockyraccoon on May 4, 2007 13:35:11 GMT -5
nice earrings!
kim
LastsGal
Post by LastsGal on May 5, 2007 13:54:11 GMT -5
Thanks, all! I've never used tape before. Sounds like it'll help a lot! Sorry, honey, I gotta go buying again! ;D
Post by creativeminded on May 7, 2007 8:49:25 GMT -5
Beautiful. Tami
