Post by Deleted on May 4, 2007 12:50:20 GMT -5
Hey all,
Just got my first "real" wire. I only bought enough for a project so I cant mess it up. It came coiled in a little circle. Its dead soft gold filled. How do I straighten the wire without kinking it up ? I am wrapping a cabojohn for my sis for her prom.
Thanks!
Shannon
Post by Jurrasic Jonje on May 4, 2007 13:11:51 GMT -5
get yourself a jewelers cloth or soft rag. Then gently pull the wire through the cloth that should straighten it out enough for you to work with it.
Post by rockyraccoon on May 4, 2007 13:32:27 GMT -5
i'm out of the blitz wipes so i'm just using my fingers and the nylon pliers. but when i have them i use the blitz wipes like jeremy describes.
kim
Post by Tweetiepy on May 4, 2007 14:31:33 GMT -5
Just don't rub them too too often or else you'll end up with half-hard wire or harder - wire hardens as it's worked & bent or rubbed
Nylon pliers are very good
LastsGal
Member since March 2007
Post by LastsGal on May 5, 2007 13:45:17 GMT -5
Just don't rub them too too often or else you'll end up with half-hard wire or harder - wire hardens as it's worked & bent or rubbed Nylon pliers are very good ^ That's what I was thinking, too. I've ruined some wire messing with it too much. I need to get some of those nylon pliers. I know someone said the customers don't notice most of the little tool marks, but they drive me crazy!
nancyf
Wired Cowgirl
Member since April 2007
Post by nancyf on May 6, 2007 8:17:46 GMT -5
Yep, nylon pliers work...and so does a soft T-shirt. I steal my DH's all the time...lol
LastsGal
Post by LastsGal on May 6, 2007 12:22:59 GMT -5
Hmmmm, thanks, Nancy! DH has more freebie t-shirts than he can possibly wear. Think one or two might have to "disappear." Hehehe
Post by Deleted on May 6, 2007 15:21:01 GMT -5
So does my husband, I will try that too.
Shannon
nancyf
Wired Cowgirl
Post by nancyf on May 6, 2007 18:28:28 GMT -5
If you are working with sterling...swipe a stick of red rouge on that T-shirt and pull your wire through the rouge spots...then sit back and watch it turn black! (the T-shirt...not the wire...lol)
Post by rocklicker on May 7, 2007 1:54:16 GMT -5
That's what I do. Sometimes I just start with curved pieces of wire, because you have to bend it around the stone anyway. Steve
Post by creativeminded on May 7, 2007 8:45:19 GMT -5
I usually keep my wire in the package it came in, find one end and gently pull the end, if it looks like it is about to kink I just reach in the bag and turn the entire coil. If you are using square wire you want to try and avoid twisting it.
Tami
