Post by creativeminded on May 17, 2007 16:26:49 GMT -5
Dragon eye is in a handflower, found the other Malachite on the internet, knowing they would go perfectly together. The earrings have malachite chips. Tami
jjckitti
Member since January 2007
Post by jjckitti on May 17, 2007 16:45:10 GMT -5
Really awesome!! I love chainmailing, and I totally understand the work that gets put into it, not to mention the expense of the rings. that is really great. oh and malachite is not cheap either. Love it!!!
spikeict
Alba gu bra! In Promptu
Member since November 2006
Post by spikeict on May 17, 2007 17:03:24 GMT -5
Great name Tami, and beautiful work.
desertdweller
Member since August 2006
Post by desertdweller on May 17, 2007 17:21:06 GMT -5
Wow, how long did it take you to do that whole set? That must of been a ton of work. Very nice!
Post by Cher on May 17, 2007 18:34:19 GMT -5
WoW!!! That's amazing Tami!
Post by larrywyland3 on May 17, 2007 18:46:20 GMT -5
Awesome
I love the use of the queens chain in the bottom of the last necklace.
Post by krazydiamond on May 17, 2007 19:22:29 GMT -5
wow, you did that up proud, Tami!!! are those green rings nobium?? that ain't cheap either!!!
beautiful set!
KD
spikeict
Post by spikeict on May 17, 2007 20:10:31 GMT -5
I have been thinking about the the cabs and the chainmail, what a great combo, your name fits once again.
Those should be in a art gallery, but the name has to be there also. Otherwise dopes like me will go to bed late in the night and suddenly realize "I get it". Thankfully I "got it" before that happened.
Spike
Post by Tweetiepy on May 17, 2007 20:35:10 GMT -5
Beautiful job Tami - that is some really small byzantine you got going there. What material are your rings? I wanted to do a Jap 12-2 draped necklace and those rings look like they would be a great material to use - love the colors & you did a great job on the wrap & the weave Euro is one of my favorites...
darrad
Member since September 2006
Post by darrad on May 17, 2007 22:22:40 GMT -5
Great name and I love malachite so I am slobbering big time. Great work!!!
Post by rockyraccoon on May 17, 2007 23:25:42 GMT -5
these are great tami! what is the bottom one?
kim
Post by creativeminded on May 18, 2007 7:26:04 GMT -5
Dragon Eye is the cab that I won in a contest here on this site a couple of years ago, it wasn't until recently that I finally found a home for it. Desertdweller, I worked on it for two days, if I hadn't had other things to do I could have done it in a lot less time. For those that asked about the wire the gold is tarnish resistant gold with the main base of copper, the green is vinyl coated copper. I get my wire at www.parawire.com the larger piece of Malachite really wasn't too bad, I got it off of e-bay, but when I saw it I just had to have it. Kim all the stone in the set are Malachite. Tweetiepy, if I remember right the ring size is either 2.5 mm.
Post by rockyraccoon on May 19, 2007 8:32:33 GMT -5
no not the stone tami - i was wondering where you wear it. does the bottom part go around the waist?
kim
Post by Tweetiepy on May 19, 2007 8:45:51 GMT -5
Kim, it's a handflower - it goes around the wrist and the small sections go around the fingers
Post by creativeminded on May 19, 2007 9:46:27 GMT -5
Tweetiepy is correct, the small rings go on the fingers and the other part goes around the wrist. Tami
Post by rockyraccoon on May 19, 2007 15:18:21 GMT -5
tami go put it on you hand and take a pic - i want to see!
kim
blarneystone
Rocks in my head
Member since March 2010
Post by blarneystone on May 25, 2007 9:11:28 GMT -5
Wow Tami!! You really are telented. The chain mail is so cool and I really like the colors in this set. Looks like something a belly dancer would wear... sexy! wooo hoo!
Post by cina on May 25, 2007 14:32:25 GMT -5
That is just one of a kind!!! Thank you so much for sharing but I to want to see it on. Steph
