Fome
Dec 10, 2003 10:16:20 GMT -5
Post by Noosh9057 on Dec 10, 2003 10:16:20 GMT -5
Can someone tell me if it is nomal to have fome in the sluge in the first stage and how much should be there.
Thanks!!!!!!!
James
Member since October 2003
Fome
Dec 10, 2003 13:24:33 GMT -5
Post by James on Dec 10, 2003 13:24:33 GMT -5
Did you add any additives to the medium?
Fome
Dec 10, 2003 15:38:43 GMT -5
Post by Noosh9057 on Dec 10, 2003 15:38:43 GMT -5
Know I just added the Grit and water.
James
Fome
Dec 10, 2003 17:14:02 GMT -5
Post by James on Dec 10, 2003 17:14:02 GMT -5
It's probably just gas build up from the jasper. Open the lid periodically to let it out and avoid the lid from poping off on its own.
Fome
Dec 10, 2003 18:15:23 GMT -5
Post by Noosh9057 on Dec 10, 2003 18:15:23 GMT -5
Ok thanks. Do you think that every 24 hours is ok to let out the gas?
James
Fome
Dec 10, 2003 22:42:53 GMT -5
Post by James on Dec 10, 2003 22:42:53 GMT -5
Every couple of days or so.
Fome
Dec 11, 2003 0:36:20 GMT -5
Post by daanserguy on Dec 11, 2003 0:36:20 GMT -5
hmmmm, could be 1 of 2 things..... a piece of soapstone might have got mixed into the batch. Or it might be see fome, got it once when I did some beech pebbles. ![:o](//storage.proboards.com/forum/images/smiley/shocked.png)
Noah
Member since November 2003
Fome
Dec 11, 2003 1:05:33 GMT -5
Post by Noah on Dec 11, 2003 1:05:33 GMT -5
Its nothing irregular I had it happen to me on this batch of assorted I was running. If it gets too foamy...just clean out the barrel and recharge it.
-Noah-
GL w/ the stone =)
Fome
Dec 11, 2003 8:39:05 GMT -5
Post by Noosh9057 on Dec 11, 2003 8:39:05 GMT -5
Thanks agen for the good info. I need all the help I can get!!!!!
Fome
Dec 11, 2003 10:42:28 GMT -5
Post by docone31 on Dec 11, 2003 10:42:28 GMT -5
I had severe foaming issues untill I replaced my water softener. Rather than go to that expense, I did it for the house water not tumbling, get some R/O water from the grocery store. If they have an outside filtering system, it should not be more than .25 a gallon. It could be the stones, but it could also be the water.
Fome
Dec 11, 2003 11:01:40 GMT -5
Post by Noosh9057 on Dec 11, 2003 11:01:40 GMT -5
Very good point about the RO water. I will try that in the nexed Re charge.
Noah
Fome
Dec 11, 2003 12:36:00 GMT -5
Post by Noah on Dec 11, 2003 12:36:00 GMT -5
Hmm...never thought about how hard the water is down this way....We get water from the NY area down here that would definately explain the Foam issue I had. As long as the stones still tumble its all good...
-Noah-
