spikeict
Alba gu bra! In Promptu
Member since November 2006
Post by spikeict on Nov 22, 2006 21:58:04 GMT -5
I would love to hear how you define that term. Is it the pattern in the rock that calls you to cut it that way? Or is it the shape you feel like you want to see that day? This came to me the other day when I took some stuff out of 60/90 to recharge it, there were some slabs that I thought now that is true freeform, I had done nothing to to them other than the slab and they looked great. I kept thm out for the next step.
Post by ladyt on Nov 22, 2006 22:06:19 GMT -5
Yep, basically it's all of the above LOL. They way you shape it or the way the rock wants to be shaped. I get some really neat shapes from the tumbler. Tonja
SirRoxalot
Member since October 2003
Post by SirRoxalot on Nov 24, 2006 11:10:30 GMT -5
I'm a noob to cabbing, and have thus been sticking to the usual ovals, rounds, and teardrop shapes so far. Freeform cabs are a great way to get the max out of expensive rough, or small and highly variable rough like turquoise nuggets, opal, or top-notch labradorite.
The problem is that it takes a good eye to make good freeforms. The majority of the freeforms I see are sort of jarring to my eye. I look at them and see a beautifully smoothed, nicely polished piece that is just cut totally wrong. And it can be as little as a millimeter between right and wrong, the eye will catch it. If I'm going to put hours of work into expensive rough, I want the end product to be symmetrical, balanced, and very pleasing to the eye.
SirRoxalot
spikeict
Post by spikeict on Nov 24, 2006 16:00:23 GMT -5
Sir you must be a woodworker also. While I sometimes "get it" I nearly always wonder what called for the shape. Those that have odd shaped bands, I can understand following them, but outside that I am a little lost.
Please know that I am just trying to understand.
Post by gemkoi on Nov 25, 2006 15:58:35 GMT -5
Good question, i think there are many factors as to why one goes with one shape over the other. wether it really works or not. Often a person like me asks if its a marketable stone, let alone the quality of the cut or finish. And all too often i personaly go with the natural shape that the stone dictates.
I would define the term as any shape not calibrated. For example; a freeform shape that one seeks out by using a template, or a giving set of measurement rules to fit a giving setting, or desired setting wouldnt be a freeform shape.
A freeform shape comes from letting the stones fall were they lie. Often when i have a fractured slab, i drop it on concrete or another hard surface and use the peices{if usable} to preform the shapes from what came of the natural breaks.
Other times i can see theres an more attractive part of the slab, and using a protactor and similar drafting tools, i will gage preprotions by drawing out lines or barriers i know i dont want in the cabochon. And as i trim the waste away, a new shape or giving shape arises.
And though the do enjoy from time to time, drawing out a final shape on the slab. These are often still rough drafts and the final shape emerges during the preforming stage.
composition like balance is important. And if you cutting cabochons as a hobby, then taking each picee you cut into this mentale is important. As i find ones who do this often want to travel into the jewelry relem, so having better balacnced cuts makes for better balanced jewelry.
I find more than offen everyone is different. And being a full time cutter, offering cabochon that one may not get, is gotton by someone else. Often i myself think what the heck did i cut? and a customer jumps on it and states how perfect it is for what they are doing.
spikeict
Post by spikeict on Nov 25, 2006 17:26:37 GMT -5
Thanks I was hoping you would respond, and LadyT I understand and agree. I am doing the ovals etc right now, nothing worth posting so far except for the tear drop that I put on the scanner so the pics did not look real great. I am doing this as a hobby for now, as I get better I may try a couple of times a year to sell some, freeform would go over better at one of those.
