dankore
Rocks, Rock
Member since March 2006
Post by dankore on Dec 27, 2006 16:27:00 GMT -5
Hi All, Here are a couple of ObsidiCabs. One is Rainbow, the other is Mahogany. Enjoy! Dan www.dbrockwerks.comKOR! ;D
Post by ladyt on Dec 27, 2006 17:15:25 GMT -5
very nice cabs. I really like the first one. Thanks for the pics. Tonja
Post by stoner on Dec 27, 2006 18:03:43 GMT -5
Nice, obsidian makes really nice cabs. I picked up some nice rainbow, I should try citting a few cabs.
junerev
Member since April 2006
Post by junerev on Dec 27, 2006 19:41:30 GMT -5
Nice cabs. Can't wait to try some obsidian I picked up.
Post by Tweetiepy on Dec 27, 2006 20:03:30 GMT -5
Nice job, obsidian is a bugger to get all the scratches out of - you did a great job! Those rainbow obsidians are amazing - the play of color is beautiful - if you can cut it right
got any tips for cutting them right?
polished
Member since February 2006
Post by polished on Dec 27, 2006 21:18:58 GMT -5
Man, those are nice ! I can't get a shine out of obsidian. If anyone wants a few hunks of black, I'm givin' them away
dankore
Rocks, Rock
Post by dankore on Dec 27, 2006 22:06:19 GMT -5
Hey Thanks everyone. Hi tweetiepy, I cut that slab or rainbow pretty much right on the flow lines, (the line that have the tiny air bubbles, that refract the light to make the colors), you should be able to see fine layer type lines, I cut as parrallel to those lines as I could, and as you dome it, you expose the other rainbow lines. In the picture the highest part of the dome is right below the flash, the darker area, and as the dome goes down it shows different colors. If you cut the slab slightly off parrallel to the lines, you end up with the rainbow sort of spread across the slab, doming doesn't change that too much. But as most rocks, each piece is different, so there is luck involved to :-). KOR, Dan
Post by rockds on Dec 27, 2006 22:44:52 GMT -5
Nice cabs, I cut up a couple of blanks today - hope to give them a try soon
Post by rockyraccoon on Dec 28, 2006 14:33:47 GMT -5
well i'm impressed because i haven't figured out how to cut this stuff right yet!
kim
Rockygibraltar
Post by Rockygibraltar on Dec 28, 2006 22:12:21 GMT -5
I keep coming back to look at the 1rst one. The shape and doming have that natural ballanced look. Good work.
dankore
Rocks, Rock
Post by dankore on Dec 29, 2006 10:51:50 GMT -5
Hi All, Thanks!!!! Obsidian can be a bit harder to polish than say agate, you would think a softer stone would polish quicker, but I've noticed on the polish wheel it can take at least 3 times longer to polish. The scratches can be troublesom. but the way I get thru it is to totally dry the cab off and inspect it before moving to the next grit, the water can hide minor flaws that show up during polish. Believe me I know :-) But dry off and check before moving to next grit. Also when polishing, let the polish wheel dry out a little and let it get a little warm, notice I said "LITTLE". The heat, or warmth helps bring the polish out a bit quicker, but you can scratch it if it gets too hot. Right when the polish STARTS to dry out, is about the best. I stand there with a spray bottle, and add about a 1/4 squirt of water at a time. Keep polishing, and it will come around if the other grits were done properly. KOR TTYS Dan www.dbrockwerks.com
