Post by larrywyland3 on Sept 11, 2007 11:36:36 GMT -5
I slabbed this nodule two ways. Here is the face of the nodule ![](http://i162.photobucket.com/albums/t280/Larrywyland3/MVC-565F.jpg) I cut off the bottom to create a second face cut ![](http://i162.photobucket.com/albums/t280/Larrywyland3/MVC-572F.jpg) This is what was cut away ![](http://i162.photobucket.com/albums/t280/Larrywyland3/MVC-573F.jpg) I decided to cut a slab to get the image of the first face cut and this is what was behind it. ![](http://i162.photobucket.com/albums/t280/Larrywyland3/MVC-574F.jpg) This is the slab size cab ![](http://i162.photobucket.com/albums/t280/Larrywyland3/MVC-579F.jpg) This photo I tried to show both faces at once. Its hard for me to believe that in one small space you can get two completely different images. I got lucky with the cut. ![](http://i162.photobucket.com/albums/t280/Larrywyland3/MVC-575F.jpg) The next cab slab is the one behind the sunset tree image. ![](http://i162.photobucket.com/albums/t280/Larrywyland3/MVC-576F.jpg) I should note that this nodule had some pits ![???](//storage.proboards.com/forum/images/smiley/huh.png) They are like pin pricks and are through out. I started cabbing and they do show a bit. Big bummer as the scene/image is so nice. This is my second nodule. I have heard that they were pit vug free for the most part; so I don't want to generalize from my two nodule experience, but felt it worth mentioning.
Post by Tonyterner on Sept 11, 2007 14:40:35 GMT -5
Seems like each cut is an entirely different piece. Cool. To bad about the pin holes though.
Post by Deleted on Sept 11, 2007 23:06:24 GMT -5
Nice scenic nodule you have there Larry. Do you have any gap filling glue? You can get some at a hobby shop with a accelerator. You just put some on the pits and spray the accelerator on it then grind away. Its like magic and works really well.
spikeict
Alba gu bra! In Promptu
Member since November 2006
Post by spikeict on Sept 11, 2007 23:24:41 GMT -5
The "the image of the first face cut and this is what was behind it." Just blows me away, the draw with brush on both sides is way too cool. I would be afraid to try to cab it for fear the good features would be ground away. If it were mine I would try to flat lap it and put the slab on display.
Spike
Post by larrywyland3 on Sept 12, 2007 18:38:47 GMT -5
nephrite... I use hotstuff. I use the real runny stuff and put on several coats. I have tried the thicker stuff, but it does not seem to stick as well as the runny stuff. I think the runny stuff gets deep into the pits, cracks and gets a hold from there.
On this one I 'll fill em; if I decide to sell them at the bead shop; I'll just disclose it. So far no has objected to the use of the liquid acrylic. I think it is only an issue if you need to solder around it. Anyone that wants to post thoughts on the use of these type of fillers; feel free. I like to hear different perspectives on it; pros cons. As far as the pits on this nodule; I'm just trying to honestly communicate what I am finding from my limited experience with the material; so if others are looking to buy some they can more informed. I am learning a lot. If this nodule had been faced from the other it would of had all those rings and I would not have bought it thinking it would not have a scene or image; that's my thing. the rings will work up nice and make a great cab; someone else's thing. Now when I buy more I know that I can get lots of different looking stuff from the same small nodule. Based on what I knew before I figured the patterns would run all the way through; with some variation.
Post by stoner on Sept 12, 2007 19:44:16 GMT -5
That's a really nice looking nodule Larry. It's amazing how different the inside looks depending on how it's cut.
firewalker45
Member since August 2006
Post by firewalker45 on Sept 12, 2007 20:21:02 GMT -5
Wow that is amazing Larry, thanks for sharing. Daniel
Post by Tony W on Sept 13, 2007 0:47:16 GMT -5
I love the tree/bushes. You got some nice material, for sure. I got to grind on mine some yesterday and I really like the way it works up. T
