Post by Deleted on Sept 14, 2007 1:26:25 GMT -5
Ok, Ive got just one more question and then I will try to leave you's guys alone for awhile.
Ive got a few agate cabs that Im working on that have druzy on them. I usually use cerium for polishing agates. Will the cerium stain my pretty druzy? Is there a way to cover the little druzy cavities while polishing? I think someone suggested to me once to use putty or something but I would think that would get stuck to all of the little druzy crystals.
Shannon
mirkaba
Member since August 2006
Post by mirkaba on Sept 14, 2007 2:04:11 GMT -5
I have put candle wax in small geodes so that they will stay together while I slab them. Heat, drain and clean with acetone. Bob
Post by stoner on Sept 14, 2007 8:16:43 GMT -5
Sugar works. KD has had success using sugar, so when she see's this, she will describe the process. I don't have any problems using diamond paste.
Post by krazydiamond on Sept 15, 2007 8:42:40 GMT -5
BearCreekLapidary revealed his secret of the druzy to me. and yes, it's sugar. place the stone on a flat surface, fill the cavity right up to the top with sugar and then dop and polish per usual. when you remove the wax (i put my dop sticks in the freezer) the sugar will rinse off/melt in warm water. you may want to save an old toothbrush along the line to scrub any other specks or dirt out of the druzy. ![](http://img.photobucket.com/albums/v292/krazyD/brazilianeye01.jpg) ![](http://img.photobucket.com/albums/v292/krazyD/Lagunawdruzy01.jpg) hope this helps! KD
jjckitti
Member since January 2007
Post by jjckitti on Sept 15, 2007 9:21:27 GMT -5
that's neat!!!!
Post by Deleted on Sept 15, 2007 12:43:37 GMT -5
Thanks for the info!
Shannon
