Polish
Dec 18, 2003 14:59:57 GMT -5
Post by Noosh9057 on Dec 18, 2003 14:59:57 GMT -5
I just wanted to know how much Polish you all us. My instrutions for the Lortone 3A states to use 6 TBS of polish for the 3 pound tumbler. Well my Research tells me to use les then that. How much polish would you all use in a 3 pound tumbler.
Thanks
James
Member since October 2003
Polish
Dec 18, 2003 17:12:11 GMT -5
Post by James on Dec 18, 2003 17:12:11 GMT -5
4 to 5 tbs. However, I'm not really sure you need that much. I've heard a number of different amounts to use. I'm also curious as to how much tin oxide should be used compared to cerium oxide. Anyone?
Robert
Member since April 2003
Polish
Dec 19, 2003 16:33:31 GMT -5
Post by Robert on Dec 19, 2003 16:33:31 GMT -5
Wow six tbls in a 3# tumbler that sounds like a lot of overkill. I start off with 1-1/2 tbsp of cernium oxide; then I recharge after 4 days with another tbsp. I have been successful doing it that way. Happy tumbling!
Polish
Dec 19, 2003 18:01:29 GMT -5
Post by Noosh9057 on Dec 19, 2003 18:01:29 GMT -5
Thanks for the info. I think you are right 6 Tab is to much. I will start out with less. But I have some time to wait becouse the bach is in the 3 week of the corses. I hope to have it in the fine by nexed week.
Thanks agen
James
Polish
Dec 19, 2003 18:54:40 GMT -5
Post by James on Dec 19, 2003 18:54:40 GMT -5
Don't forget to save and reuse you polish.
Polish
Dec 20, 2003 8:43:30 GMT -5
Post by Noosh9057 on Dec 20, 2003 8:43:30 GMT -5
Yes I will reuse the polish. Can you reuse it forever? Or how long can you reuse it for?
Thanks
James
Polish
Dec 21, 2003 13:18:25 GMT -5
Post by James on Dec 21, 2003 13:18:25 GMT -5
You can use it as long as you want if it's kept clean. If at any point it becomes contaminated from a previous grit, it will become useless.
Polish
Dec 21, 2003 15:15:27 GMT -5
Post by Noosh9057 on Dec 21, 2003 15:15:27 GMT -5
Ok thanks. I will be shere to clean very good at the Pre Polish stage.
jdmaney
Member since August 2003
Polish
Dec 22, 2003 11:41:53 GMT -5
Post by jdmaney on Dec 22, 2003 11:41:53 GMT -5
I was wondering how different types of rocks within 2 hardness would hurt the polish. How much does this affect the final pollish?
James
Polish
Dec 22, 2003 13:58:25 GMT -5
Post by James on Dec 22, 2003 13:58:25 GMT -5
The harder rocks chip and scratch the surface of the softer rocks.
