Post by MrP on Jan 6, 2008 15:39:13 GMT -5
Thought I would make each a set with the same material. Moss Agate Wife 1st daughter 2nd daughter Rose Quartz Close up MrP
huffstuff
Member since August 2007
Post by huffstuff on Jan 6, 2008 15:46:57 GMT -5
Wow! Didn't you just show us a billion pendants and earrings and such from Christmas? You are amazing at the amount of jewelry you craft!
I think I missed this in another thread - how do you drill your holes? You can PM me if you want, so I don't get this thread off track.
Beautiful stones, lucky wife & daughters!
Amy
Post by MrP on Jan 6, 2008 16:11:32 GMT -5
Amy I use Tripple Ripple 1.1 MM drill bits from Kingsly North for my starter hole then larger sizes as needed. www.kingsleynorth.com/skshop/search_results2.php?catID=191I am also using Lube Cool4800. www.kingsleynorth.com/skshop/search_results2.php?catID=424 I use a small pan with the Lube Cool in it and have a slab that is at an angle, so the one end is at the bottom of the pan and the other end is out of the water. That way I can hold the pendent in any amount of water I want. When the bit starts drilling slow I just drill into a small piece of obsidian and it will drill like new again. I use a Dermal, just hand held.....MrP
Post by Bikerrandy on Jan 6, 2008 16:19:10 GMT -5
Great stuff bud, the moss is awesome!!
Post by cina on Jan 6, 2008 16:21:16 GMT -5
Nice Work!!
deedolce
Member since October 2006
Post by deedolce on Jan 6, 2008 18:20:32 GMT -5
Love those! Moss is a fav, and rose quartz goes with *everything* I bet they absolutely loved them! Dee
Post by beefjello on Jan 6, 2008 20:36:01 GMT -5
Wow you've been just crankin' them out! Beautiful pieces, I really like the moss.
Post by Tonyterner on Jan 7, 2008 15:20:27 GMT -5
The moss ones are really nice. I like the others too.
