Post by Titania on Feb 14, 2008 8:18:31 GMT -5
Is the # of wires you use in your wraps up to whim or is there some design philosophy behind it? I did my very first wraps last night (pics later). My first used 5 wires, the 2nd 3. I realized only after the fact that the books I have use 2 to wrap cabs. I'm not super excited about how sturdy that would be, but maybe I'm just being paranoid. Finding homes for 10 ends is sure tricky!
Sparky
Still diggin'...
Member since October 2007
Post by Sparky on Feb 14, 2008 15:44:53 GMT -5
For my traditional style wraps, like the wrap in my avatar, I use only 1 or 2 wires.
But with border wraps I use anywhere from 3 to 6 depending on the thickness of the stone. I just finished a border wrap on a cab that had a 1/4" thick girdle and used only 3 wires. IMHO, I wouldn't use only 2 wires on any border wrap for the same reason you mentioned.
I'll post pics of it as soon as I can pry it out of my wife's hands...lol It was part of her Valentine's Day from me.
Hope this helps.
Rus
Post by akansan on Feb 14, 2008 16:08:35 GMT -5
It partly depends on the thickness of the flat. I like my wires to cover the flat edge completely in the bound spots, and that's normally four wires. You can create a perfectly stable wrap with only two wires. Let me dig through the archives to find some of rockds's wraps - he almost always used 2 wires. Design-sense wise, odd numbers are generally preferable to the eye than even numbers. Think of flower petals - most flowers have an odd number of petals... Additionally, you can always clip extra ends. It's taken me over a year to get to that point (what! clip off perfectly good wire? ), but it is an acceptable, and sometimes preferable, solution.
Post by akansan on Feb 14, 2008 16:16:33 GMT -5
Tigger
The Wonderful Thing About Tiggers is I'm the Only One!
Member since January 2008
Post by Tigger on Feb 14, 2008 16:26:34 GMT -5
Rhonda is right. Also, it depends on the look your going for. I usually use 3 wires. I like the look of wire on the edges. I have used 2 and as many as 4. I too have a hard time finding places to hide the wire ends and the less amount of ends the better.
Tonja
Post by Cher on Feb 15, 2008 2:09:30 GMT -5
For me, the first thing I consider is the thickness of the stone, second is the shape. Most of the time, I use four wires but have done small pieces with two wires and a few with three. Ends definitely are the pain and unfortunately, I have not reached the point where it's ok to just cut them off. ;D Though I can see where doing that would definitely make things easier for finishing.
Shelbeeray
Member since January 2006
Post by Shelbeeray on Feb 15, 2008 2:18:23 GMT -5
Wow. That second wrap of Rockd's is still a class act to me. It's unique. I go along with the others, I like to stack the wires next to the stone and will have as many as the stone looks like it needs. I usually use 3, although now that I like to incorporate crotcheted wire into the frame, I use the wire differently. But on regular wraps, at least 3.
Post by Titania on Feb 15, 2008 8:20:06 GMT -5
Thanks for the advice, everyone! Those wraps of rock's sure look more sturdy than the design in my book. I really like those!
Post by akansan on Feb 15, 2008 12:07:35 GMT -5
I just remembered - Blarney's crosses and a couple other of his started out with two wires as well. Cher - I might be at the point where I can snip wire, but that doesn't mean I do it regularly! And I admit- part of the reason I'm okay with it is I anticipate a time soon when I'll be melting my scraps for repurposing.
