lsmike
Maxwell's demon lowers tumbling entropy
Member since January 2007
Post by lsmike on Feb 22, 2008 11:55:18 GMT -5
![:)](//storage.proboards.com/forum/images/smiley/smiley.png) I was visiting with Val Carver at Minnesota Lapidary Supply-he is a fount of great lapidary information.This time he showed me a dozen small cabs of the same shape and size that an old time cabber had polished as examples of his work.I had to agree with Val that these were as good as it gets.They were all of different material and ranged in hardness from about 5 to seven-and -a-half,all done together.He uses a Gy-Roc 10#. He uses 800A.O. as a pre-polish,one Tablespoon per 10# of load.Then Rapid Polish#61 about one teaspoon per 10#--no more!Two day runs should do it.He also adds about the same amount of cheap hair-gel --this probably starts he slurry faster and acts a a surf actant. Also important,he uses about 80% small size plain[uncharged] ceramic cylinders-this really works the load. Val tells me that the only thing he has found that R.P.#61 won't polish well is feldspar.Try it I think youl'll like it.Mike.
Post by deb193redux on Feb 22, 2008 12:30:59 GMT -5
Well I thinkit is the ceramic more so than the polish. But when I get my Gy-Roc set up again, I will try some 61.
FYI, I have had very good luck polishing pink feldspar for some kids' pendnats I made last year. I used AO in my Lot-O.
Post by johnjsgems on Feb 23, 2008 0:21:51 GMT -5
If my fuzzy brain is right, Rapid Polish 61 is "submicron aluminum oxide".
lsmike
Post by lsmike on Feb 24, 2008 12:58:39 GMT -5
![:)](//storage.proboards.com/forum/images/smiley/smiley.png) Yes,#61 is sub-micron A.O. My understanding is that A.O. comes in two "phases"-#61 is made from the harder phase so it resists breaking down;that's why you don't need much.Mike.
