geogoddess
Member since December 2007
Post by geogoddess on Apr 21, 2008 10:44:20 GMT -5
I've been working on some Sodalite and Amazonite, since they're about the same hardness. But I didn't get enough cushioning in the later stages so my sodalite has the crackling around the edges from bouncing around. I know how and why it happens... so my question is....
How far back to I need to put the sodalite in order to get rid of the crackling? Can I start at the medium? Or should I go back to the coarse?
Post by Bikerrandy on Apr 21, 2008 18:30:09 GMT -5
If you're still satisfied with the shape, you might be ok to just go back to the medium stage. Sodalite is soft enough that medium should cut them just fine.
rollingstone
Member since July 2009
Post by rollingstone on Apr 21, 2008 18:32:17 GMT -5
I second Randy's opinion. -Don
geogoddess
Post by geogoddess on Apr 21, 2008 18:52:07 GMT -5
Yeah, the shape on most of them are fine. Some of them weren't as crackly as I thought they were. But they'll all go back through.
Thanks!
lowkey
Member since April 2008
Post by lowkey on Apr 25, 2008 9:01:21 GMT -5
I hope I get it right, Sodalite will be my 1st load to tumble. I will be using a Lortone 45c rotary tumbler for the rough tumble. And the I will use a vibe for the rest.
Wolfden
Member since November 2007
Post by Wolfden on Apr 27, 2008 19:02:42 GMT -5
I just did some awhile back , I started using plastic pellets about the 220 stage and didnt have any frosting good luck
Wolf
