colliel82
Member since November 2007
Post by colliel82 on May 3, 2008 18:29:04 GMT -5
I bought a used viking vt-14 vibrasonic tumbler. Does anyone have instructions or know where I might be able to get them. I haven't had much luck contacting Diamond Pacific for instructions.
Thanks
Diane
Post by deb193redux on May 3, 2008 19:17:28 GMT -5
I think you could pretty much use the Lot-O instructions at therockshed.com. Check them out. But basically damp rocks so the grit sticks, and use ceramic to help get the load right. Start with 120 or finer - not 90g. If you want, the guy who invented this tumbler wrote a book: www.mamasminerals.com/page/MM/PROD/BOH-TUMPOSome folks here have the big vibrasonic 40lb unit. I will be setting up a minisonic 4lb unit soon. Keep in touch.
colliel82
Post by colliel82 on May 3, 2008 19:40:48 GMT -5
Thanks for your help. I appreciate the info.
Diane
Post by johnjsgems on May 4, 2008 8:01:22 GMT -5
Diane, Don Depue at Diamond Pacific would be the one to talk to. What specific info do you need? I should be seeing him next weekend at the Grand Junction show and can pin him down there. He is very sharp on all the technical how-to's.
dshalldms
Member since January 2008
Post by dshalldms on May 5, 2008 12:14:19 GMT -5
Hello Diane,
I have an instruction manual for the old Geode Industries VT-35.
What do you want to know!
Derek
colliel82
Post by colliel82 on May 5, 2008 15:38:40 GMT -5
Hi Derek
Thanks for the help. Johnsjems is trying to get me a parts list, and instructions for the vt-14, but in the meantime, I need to know about how much grit and water to use..........I know a vibe is alot different from a rotary, and how full to fill it.
Thanks
Diane
Post by deb193redux on May 5, 2008 21:17:38 GMT -5
I can tell you how much water to use - none that don't stick to the rocks. It does notmatter what brand of vibe. You rince the rocks and dump out the water. Thats it. IF you notice too much slowdown after you add the grit, you can squire a few times with a spray bottle.
The may be more exact information in the booklet on the fill, but "mostly full" - that gives the proper weight the motor and springs are designed for.
Good luck
Post by Jack ( Yorkshire) on May 7, 2008 1:55:12 GMT -5
Hi Excelent advice from Deb193redux, above If you add a lot of water you end up with a rock "washing machine" washes all the grit to the bottom of the barrel, As above , tip it ALL the water out add 1/2 tea spoon of soap flakes to help the grit stick to the rocks and away you go as Deb says if they start to go slugish just add a few squirts of water If you want Connrocks recepie for the 4 1/2 lb Loto"O" which I have sent out to a few people email me john@matco.me.uk and you can get results like this forum.rocktumblinghobby.com/index.cgi?board=trtphoto&action=display&thread=23276Hope we have been of assistance to you Have a good day Jack Yorkshire UK
dshalldms
Post by dshalldms on May 7, 2008 14:31:07 GMT -5
I have scanned a copy of my old 1972 VT35 Instruction Manual Page1 Page2 Page3 Page4 Page5 Page6 Page7 Page8 Hope this helps, Derek
colliel82
Post by colliel82 on May 7, 2008 15:35:24 GMT -5
Wow!!! Thanks for your hard work Derek. It makes a huge difference to be able to see this.
iamkjo
Member since December 2012
Post by iamkjo on Dec 4, 2012 15:50:00 GMT -5
thank you so much for posting this manual...it is a life saver!
snowdog
RIP David Fildes, aka: snowdog
Post by snowdog on Dec 4, 2012 20:56:27 GMT -5
diane --- the only thing I would add is that I start with 220 grit ( nothing courser) -- I use too, but ,I have wore out 2 barrels over the last 30 years !! ;D --- think the biggest prob was that I had one big rock ( baseball size) and the rest were smaller -- the small ones couldn't push the big one up the side ,so it would just turn at the side/bottom where most the grit was --wore a hole right where the big rock was
colliel82
Post by colliel82 on Dec 5, 2012 0:26:24 GMT -5
Its been a few years since I asked for this info, and I still refer back to it. Diamond Pacific now owns these tumblers and resurfaces the barrels. I sent mine back to them and in a short time received a newly surfaced barrel in the mail.
