Post by rockyraccoon on Jan 1, 2004 13:29:36 GMT -5
what size rock to most of you prefer to tumble?
Post by hermatite on Jan 1, 2004 13:59:13 GMT -5
Well, I don't have a lot of experience yet, but I know that in my last batch I threw everything in...all the little splinters from every rock that I cracked with the hammer. And at the end of the polishing stage some of my favorite stones were the wee tiny ones...I think they'd look great around the base of a plant...hey...maybe even a bonsai tree. If I was braver I'd try drilling a couple of them for beads...but as it is now I just like playing with them. So, in answer to your question, I'm moving to smaller rocks with this next load.
Noah
Member since November 2003
Post by Noah on Jan 2, 2004 0:14:33 GMT -5
My favorite is 1-2lb pieces. Specially when your making table ornaments. I cheat with this I cut it, grind it a bit, tumble it, grind it again and then tumble the rest of the way...seems to get through the process a lot quicker and cheaper I've been able to produce some of larger book ends type stuff in about 2 days...since mostly I use the tumble time for pre-polish...and polish...but then again it all depends on the stones....I have been experiment with using a high speed rag wheel to polish them, but for some reason I like the tumbled look.....
James
Member since October 2003
Post by James on Jan 2, 2004 21:34:57 GMT -5
Smaller, 1/2" to 1" rocks are the easiest to tumbler and produce the best results. Rocks approching the 2" to 2 1/2" range take longer and tend to chip the other rocks in the barrel.
I personally like to start off with larger rocks and grind them down into nice round shapes. I usually wait for around 40% to 50% of the origional rock to grind down before I move to the next grit.
