indigoace
Post by indigoace on May 19, 2008 18:20:13 GMT -5
I'm a total newbie with a new Lortone Model 3-1.5B, and one of my barrels has a cement-like sludge at the bottom. What steps do I need to take so that my rocks can tumble freely?
lparker
Member since March 2008
Post by lparker on May 19, 2008 19:37:42 GMT -5
Soak it overnight and gently scrape it out - meaning don't use anything that will cut the barrel. Seems to me that if it is new it should be clean - do you mean a new used one?
indigoace
Post by indigoace on May 19, 2008 21:02:00 GMT -5
Sorry, I wasn't clear. The tumbler is new & I've been running it for over a week. Yesterday, I took some rocks from my first grind that weren't done yet & reloaded two barrels with 60-90. When I checked today, one of the barrels had the thick sludge at the bottom with the rocks wedged in. I took everything out & stirred to get the (mostly grit) layer off the bottom, but what else should I be doing?
Post by akansan on May 19, 2008 21:44:56 GMT -5
How's the mix of sizes in your barrel? If the rocks are all one size, this can happen (the little guys help keep things stirred up).
Post by deb193redux on May 20, 2008 0:11:38 GMT -5
It is a puzzle. A poor mix could let grit fall to bottom, but it should not cement as long as the barrel is truning and there is water. If the barrel stops, and the water leaks, it would cement onthe side.
For sludge on the bottom, it had to settle after the barrel was set upright - but it still would need too little or way too much water.
Any more info?
Post by Jack ( Yorkshire) on May 20, 2008 1:55:57 GMT -5
Hi Indigo ace, Is it a rotary or vibe , I dont know from the numbers If its a Rotary you need more water If its a Vibe you have too much water and all the fine stuff is setteling out at the bottom of the barrel put less water in IN fact No water at all, after filling fill WITH water add Rocks then tip ALL water out this leaves the rocks wet so grit sticks to them . There you go, there is the theory now put it into practice If you need more detail and it is a Vibe & you would like "Connrocks Vibe recepie" email me john@matco.me.uk. This is the results you shhould get forum.rocktumblinghobby.com/index.cgi?board=trtphoto&action=display&thread=23276This is for the Lot"O" 4 1/2 lb machine but you can adjust it to your load size. Have a good day Jack Yorkshire UK
indigoace
Post by indigoace on May 20, 2008 4:14:05 GMT -5
Thanks! It's a rotary, & I think that I probably don't have enough small pieces left in the mix. I'll throw in some ceramics & see if that helps.
Post by deb193redux on May 20, 2008 10:45:56 GMT -5
But did you trun it upright and let it sit for a bit of time before you opened it? Otherwise how did hte cement get on the bottom?
indigoace
Post by indigoace on May 20, 2008 19:34:07 GMT -5
I think the problem may have been at the beginning, actually.
I was prepping two barrels at the same time. I checked the levels & adjusted the rocks, then I added the grit to each, then the water, & only then did I put the barrels on the tumbler. I think that this slight delay kept the first barrel sitting too long so that the grit stuck itself to the bottom. Next time I have more than one barrel, I'll finish the first & put it on the tumbler before adding the grit & water to the 2nd.
Does it make a difference if you add the grit last?
Post by deb193redux on May 20, 2008 21:33:36 GMT -5
I think it would be better if the grit was sprinkled on top of the rocks -- BUT new, fresh, loose grit, especially course, would fall right off the bottom as soon as that barrel started turning.
Still a mystery here.
Post by Jack ( Yorkshire) on May 21, 2008 1:47:57 GMT -5
Hi I put it all in together water/ first then grit/ paste granuals / soap flakes /a bit of powdered rock dust of the grinder (stage One),
If it all falls to the bottom 1/2 a revolution and it will be on top !!? it dosent matter at all just get the barrel rolling !!!
Jack Yorkshire uk
Post by akansan on May 21, 2008 9:34:59 GMT -5
I've had this happen before - and unless the settling would happen within 1 minute, that wasn't the problem.
Just out of curiousity, did you have any flat sided pieces? The other time (besides the one where I didn't have a very good mix of stones) I had a flat piece that landed flat side down on the bottom of the barrel when I put it all in. When I unloaded the barrel, that flat piece was REALLY flat on the side (from where it rubbed against the bottom of the barrel constantly) and I had to work to get the thick sludge out of the bottom.
And I've normally done two or three barrels at a time - stones, then grit, then water. The "cement" effect has only happened to me twice. Once, I attributed to the load - too few small pieces to keep the rocks from wedging in the bottom. Once from the flat piece that glued itself to the bottom.
Post by LCARS on May 25, 2008 15:50:16 GMT -5
Sludge happens, it's normal. Just reseal the barrel, turn it end over end for about a minute or two by hand and then set it back on the rollers. The sludge will work itself loose and go back into suspension (slurry) just as it's supposed to.
Post by Noosh9057 on May 28, 2008 14:28:32 GMT -5
Sometimes this will hapen if you put in to much grit. I liker to take the barre off the tumbler and shake it a little every other day. This also helps the problem.
Roger
karenfh
Member since November 2006
Post by karenfh on Aug 14, 2008 23:30:22 GMT -5
I had that problem in my vibe, but it was my own fault; I was running stuff that I knew would erode fairly quickly. Never had an issue in the rotary, tho, even when I broke a belt and it didn't rotate for a day. I found that the turbo setting on the nozzle on the hose cleaned it all out pretty darn quick, haha! K
indigoace
Post by indigoace on Aug 15, 2008 0:53:41 GMT -5
It's much better now. I now add some smaller pieces (mostly garnets) & give the barrel a shake before I set it going.
Post by connrock on Aug 15, 2008 5:27:55 GMT -5
If your load is of the right size rocks you should never have to shake the barrel. Remember.....AT LEAST 1/3 of the load MUST be small rocks in order to have the proper action in the barrel as it rotates. We all get a little "greedy" at times and want to put all the "good" stuff in but that's wrong! If your barrel(s) are loaded properly you can listen to them talk to you as they rotate. A "happy" barrel will sound as if you were pouring pebbles from one hand to the other. "Hey man,,,,this is one smooooooth ride" ;D An"un-happy" barrel will holler out at you with a clunkity clunk voice just to let you know it's not "comfortable"."HEY,,,,,I'm gettin all banged up in here"! The 1-1/2 lb barrels can be a bit "testy" to load as they are small and won't take many bigger rocks. The larger barrels are much more forgiving. Listen to your barrels and once you can understand their "lingo" you will know EXACTLY what is going on inside without having to open them. Too much "woosh"= too much water Clunkity clunk = not enough water. Try a test load with the correct load and no grit.Another with too many big rocks and listen to both of them. The "happy" one will sound just about the same after you add the grit! connrock
lsmike
Maxwell's demon lowers tumbling entropy
Member since January 2007
Post by lsmike on Aug 15, 2008 13:50:31 GMT -5
My #1 suspect would be too little water.I put the rock and grit in,shake it a bit to settle the load then add water to just under the first layer of rock.Soft rock,as mentioned,would surely be suspect too-it would turn into mush.Mike.
Shelbeeray
Member since January 2006
Post by Shelbeeray on Aug 15, 2008 23:56:52 GMT -5
I'm glad someone brought up the concrete problem. I've been too embarrassed to ask about it. I have yet to have a successful tumble with my vibe. I was using a spraybottle to dampen the rocks after I dumped in the grit. Think makes a heckuva ruckus. Next day it was darned quiet and turned out to be half filled with concrete (reminded me of when the kids were little and I knew there was trouble if things got quiet...). I was tumbling a load of mostly milky quartz. I put in a ton of water, which loosened up the sludge and then tumbled with a wee bit more water. Now they're in polish with extra water again. But, just enough to keep the rocks coated. I just don't know what to do. I've been so darned frustrated with this thing. Fortunately, my Lortone barrels keep on tumbling..never a complaint or problem.
Post by connrock on Aug 16, 2008 4:09:08 GMT -5
Shelbeeray, What brand tumbler do you have?
connrock
