minerjohn
The wild bunch!
Post by minerjohn on May 21, 2008 21:56:01 GMT -5
I hope I can ask this here. I have an 8" flat lap that I'm learning to grind on. I've tried polishing with cerium oxide and just don't like it. Is there something better I can use on my lap to get a nice glossy finish or do I need to use a different piece of equipment. Thanks, Miner John
Post by johnjsgems on May 21, 2008 22:49:56 GMT -5
Are you using a High Tech Diamond or Ameritool unit? If you bought it complete it should have a polish pad and 14000 diamond compound. It would work better with a sponge pad under the polish pad to cushion. Agates and jaspers should polish up nicely on a felt or leather pad with cerium. Aluminum oxide in a .5 micron or finer will polish softer materials as well as the agates/jaspers. Dampen the polish pad with water. Mix the polish with water and brush on the pad. Should work. I'm assuming you went through sanding steps before polishing.
adrian65
Member since February 2007
Post by adrian65 on May 21, 2008 23:09:10 GMT -5
I do all my polishing with some flexible diamond pads that I stick on the flat lap. It works great. Tried with cerium oxide on felt in the beginning, but it was a mess.
Adrian
