lowkey
Member since April 2008
Post by lowkey on May 22, 2008 11:23:30 GMT -5
I bought 80 grit, the Question is 80 verses 60/90 which do you use?or which is used for what rough?
thomtap
Member since December 2007
Post by thomtap on May 22, 2008 11:28:33 GMT -5
If you are using a rotary tumbler either will work. The 60-90 might be a bit faster, but not much. If you are using a vibe you should start with 220 or so.
Thom
chassroc
Post by chassroc on May 22, 2008 14:00:35 GMT -5
There is a company called Jasco that sells single grade grit and insinuates that it produces more consistent results; I don't know if that is true but I'm thinking it matters little until you get very experienced and keep prodigious records and photographs highly magnified.
Most of us run the coarse stage until the rocks are well formed and rounded and if that takes more time with single graded grit than a range of grit sizes is probably not as significant as just getting well formed rocks.
After saying all that, I am starting to wonder if single grade grit does make a difference. Anyone taking notes and pictures out there? csroc
Post by deb193redux on May 22, 2008 14:29:15 GMT -5
I heard single grade was more useful for lap'ing. In tumblers it is just more expensive, but not harmful.
Post by johnjsgems on May 22, 2008 15:07:33 GMT -5
What deb193 said
Post by Condor on May 22, 2008 20:59:44 GMT -5
To me they are about the same except for the price. Graded are a little more expensive.
Condor
Post by johnjsgems on May 23, 2008 10:15:40 GMT -5
Graded grits cost more than mixed grades. 60/90 is a mixture of 60-90 grit, average 80. I doubt you would notice a difference in a tumbler. Where it might make difference is in higher grades. 220 graded is finer than 120/220. Flat lappers generally say it matters and buy 220, 400 and 600 grit. Tumbling grit runs longer and runs while breaking down so mixed grade works just fine.
