keith503
Member since February 2007
Post by keith503 on May 25, 2008 10:18:12 GMT -5
Has anyone tumbled obsidian with good results... either slabs, or whole pieces. I tried a coulpe slabs with a batch of material and it came out really dull, it is cool if you look at it thru a light Thanks Keith
turquoiselover
Member since January 2008
Post by turquoiselover on May 25, 2008 11:30:55 GMT -5
I'm on my 4th batch of obsidian slabs (I'm planning a windchime project) and have had great results. The flow lines show really well in the sunlight, which is why I thought of windchimes.
My formula: I mix the slabs (edges rounded off with the trim saw) with cubes. I cut cubes of obsidian to keep my saw blade clean, so they are really just a by-product of saw usage. In my 3# barrel, I can fit 6-8 slabs, and a dozen or so cubes, depending on the size. I cut cubes 1/4" to 1/2". Then add about 1/2" of ceramic beads. I've tried plastic beads in different combinations with obsidian, and HATED my ceramic beads at first. But the ceramic beads just work really well with obsidian. I run for 2 weeks in 69/90, re-charging after a week (or so). Then 10 days in 120/220. Be sure to check the barrel now and then - obsidian is gassy, and may need a gas-relief tablet or two. I then run for just 5 days in 500 pre-polish, then burnish really well (24 hours this time) with borax. Then add polish - tin oxide seems to work the best. I get a glossy, drop-dead finish in about 5 days. I read through a lot of recipes on this board and other places on the net and tried Karo syrup, sugar in the mix....all kinds of combinations - and messes! This one just seems to come out consistantly beautiful.
Turq
rollingstone
Member since July 2009
Post by rollingstone on May 25, 2008 12:23:41 GMT -5
keith503
Post by keith503 on May 26, 2008 11:11:44 GMT -5
Thanks Guys, I will give it a try when the stuff I am tumbling now is done. I have about 25 lbs of snow flake, and mohagany. Keith
