Post by deb193redux on May 28, 2008 11:29:25 GMT -5
I have an old qt-66 and the new belt is slipping. I adjusted the motor mount to increase tension. But after a few days, it is sliping again.
Is there some sort of spray-on belt dressing that stops slipping? WOuld auto-zone have it?
Post by kap on May 28, 2008 11:34:08 GMT -5
Yes any auto parts store should have belt dressing. You said this is a new belt is is the right width if it is too small it will not set in the pulleys tight enough and can slip. Keith
