yotmv
Member since June 2008
Post by yotmv on Jun 4, 2008 23:37:42 GMT -5
I happen to have around 200lb's of HPA 60 Garnet Abrasive According to the mfg, at roughly 80 Tyler Screen or 180 micron, 90% of the product will be retained. I am not entirely sure how this compares to, say 60/80 SiC.
My biggest question is do you think it would work with quartz based materials for use in tumbling?
I have a 15lb rotational tumbler & a 4lb vibrational tumbler. Unfortunately, I won't have access to them until Friday afternoon. I want to start a cycle up this weekend and can either drive & pickup some SiC or use this Garnet.
Anyone have experience?
rollingstone
Member since July 2009
Post by rollingstone on Jun 5, 2008 1:22:41 GMT -5
Hmm, I'm not really sure of the conversion either, but I'm thinking you have the equivalent size as 80 grit (based on the 80 screen). Some people use straight 80 SiC for coarse grit, but most use 60/90 because it is cheaper than a straight size grit. Using your garnet grit won't hurt anything, but I see two reasons why it won't be as effective as SiC on quartz hardness stones. First, and I suspect you already know this but I'll include it here for completeness, quartz has a hardness of mohs 7, garnet is around 7.5, and SiC around 9.1-9.3. So garnet is harder than quartz and will work as a grinding agent, but SiC is much harder so will work better. More importantly, SiC is hard but brittle, so it tends to gradually break down into finer sizes by fracturing into smaller but still very sharp pieces that cut aggressively. Garnet on the other hand, doesn't fracture, instead it wears away gradually, becoming more rounded and smaller... and more like ball-bearings than a cutting agent. To demonstrate this (ignore the different scales please!), here is 60/90 SiC, magnified with my macro lense -- nice and sharp, and you'll have to trust me that it continues nice and sharp as it fractures into smaller pieces ;D And here is some garnet I tumbled -- it's much larger than your garnet grit, but gets rounded in the same fashion. After a short time in the barrel (maybe right from the start), the garnet just doesn't cut rock very well because it's round, not jagged and sharp. -Don
yotmv
Post by yotmv on Jun 5, 2008 9:20:07 GMT -5
About what I was afraid of Unfortunate too, as I know the price of the garnet is around $0.19/LB versus the $1.20 I pay for the SiC Looks like I'll be picking some up today/tomorrow. thx!
Post by akansan on Jun 5, 2008 10:43:28 GMT -5
Don, I never get tired of seeing that picture of your garnets. Such pretty, pretty lovelies.
Post by Tweetiepy on Jun 5, 2008 14:11:07 GMT -5
Pomegranites!
i could bathe in those!
Post by johnjsgems on Jun 5, 2008 14:42:00 GMT -5
"Garnet Sand: An excellent aid to grinding and polishing stones or glass in a vibrating or rolling tumbler. It's small size helps aid in grinding and polishing those tough to get areas. Use about 1/4 cup of garnet per quart of rocks. Use mixture from rough grind all the way to polish. Garnet sand 8/12 mesh." Page 37, Covington catalog. Looks like you would use it with S/C grit.
Roan
Member since January 2008
Post by Roan on Jun 29, 2008 9:50:03 GMT -5
I would kill for those garnets. I can't find large lots of nice tiny ones anywhere.
Eileen
