isuckatlife
Member since June 2008
Post by isuckatlife on Jun 5, 2008 8:49:00 GMT -5
I have found some interesting rocks here in Iraq that already have a *very* desirable shape and are smooth, I was wondering what y'all would recommend for tumbling, whether or not to skip the course stuff? Any help is much appreciated, Lyle.
rollingstone
Member since July 2009
Post by rollingstone on Jun 5, 2008 10:18:47 GMT -5
If it were me, I'd run them for a week in coarse grit just to be sure. Because if the surface isn't really quite as smooth as you think it is, then all the other stages will be a waste of time. -Don
Post by Noosh9057 on Jun 5, 2008 10:19:56 GMT -5
Most of the time I like to run at least one week in the course. But if thay are smooth with no sharp Edges then you should be able to skip the course and go right to the fine.
Roger
Post by johnjsgems on Jun 5, 2008 10:43:56 GMT -5
The 60/90 step rounds the rocks to the shape you want. The subsequent steps mostly remove scrathes from previous steps. If you like the shapes as found you can skip the 60/90 step with no problem.
isuckatlife
Post by isuckatlife on Jun 5, 2008 12:24:14 GMT -5
Thank's y'all for the quick advice. <3
