Post by rocklicker on Jun 16, 2008 1:52:05 GMT -5
This old girl was getting tired. The motor was loosing it's oomph so I replaced it. I'm one of those types to make use of whatever's around. Instead of buying a new motor, I used one out of the downstairs bathroom fan. We had it unplugged anyway becuse it made a lot of noise under the stairs. I found an old pulley from a CE tumbler, put it all together and whamo, new tumbler! Here's the rebuild: ![](http://i48.photobucket.com/albums/f240/rocklicker/Kitchen2129.jpg) And... It works! Here is is with a new batch of varoius quartzes (rose, amy, smokey). It feels right at home with the other tumblers. Look at her roll! ![](http://i48.photobucket.com/albums/f240/rocklicker/th_Kitchen2133.jpg) Steve
Post by Noosh9057 on Jun 16, 2008 7:03:15 GMT -5
Well it should work for years now.
Roger
Post by johnjsgems on Jun 16, 2008 8:20:39 GMT -5
As long as the rpm's are the same and h.p. (usually expressed in current draw on that type motor) is the same or a little higher it should work fine. Lortone buys their motors from someone.
Post by rocklicker on Jun 16, 2008 14:06:18 GMT -5
I timed the barrel speed and it's really close to that of the Lortones. The motor was rated at .65A. I did a little spin test with the older and newer motor by grabbing the shafts with my fingers to see how strong they were. It was defenetly stronger and the barrel didn;t slow down when I aplied a little preassure. No I just hope my wife doesn't notice that we have no bathroom fan in the half bath ;D Steve
Gem'n I
Member since March 2008
Post by Gem'n I on Jun 16, 2008 19:08:54 GMT -5
Just stay away from the refried beans and you should be good to go....great save on the tumbler!!!
Larry
Post by joe on Jun 16, 2008 23:39:45 GMT -5
Great repair! I like it!
Post by Jack ( Yorkshire) on Jun 17, 2008 2:35:24 GMT -5
Good job Great Idea, Thanks
Jack Yorkshire UK
drjo
Honduran Opal & DIY Nut
Post by drjo on Jun 20, 2008 21:05:12 GMT -5
Similar motors can be found in older large microwave ovens also (the larger the better).
Dr Joe
