lsmike
Maxwell's demon lowers tumbling entropy
Member since January 2007
Post by lsmike on Jun 29, 2008 17:40:59 GMT -5
This is something many of you may have discovered,but it took me 'til recently.Pretty end cuts are something I just used to keep 'cause they were too nice to toss.I'm talking mainly about ones from nodular{rounded} rocks.These are arready half way to being domed.They may need a bit of shaping first.I have found also that, if the stone has pits or other rough spots around the edges ,it helps to take off a thin slice on the end that will be domed-less grinding will be needed.Mike.
Post by fishenman on Jun 29, 2008 20:36:36 GMT -5
Yes Mike, it's a great way to finish off a rock. I agree there's more to grind. Good suggestion to make a small cut on top of the dome.
Post by joe on Jun 29, 2008 22:54:44 GMT -5
I've used end cuts to make cabs too. Sometimes you have to grind down a bit to get to good solid rock but it's worth it. There are some gems hidden in those ends!
karenfh
Member since November 2006
Post by karenfh on Jun 30, 2008 23:18:33 GMT -5
Adrian did a super job on an end cut (and it was a small end cut!!) Wow, it turned out beautifully. I am sure most of you saw this, but if not...I am going to post his thread here. I renamed it trouterite or troutitella. Turns out it was Montana Agate. But truly, it was a very small piece, and he did an amazing job. So keep those end cuts! They can be priceless. forum.rocktumblinghobby.com/index.cgi?board=ccabs&action=display&thread=23885K
Post by stonesthatrock on Jul 1, 2008 22:03:13 GMT -5
i sell my ends you to guys lol I'm working on alot of green stuff, holdemplayer??? hehehe
Post by Tonyterner on Jul 2, 2008 10:51:00 GMT -5
I use end cuts all the time.
