Post by deb193redux on Jul 18, 2008 0:03:44 GMT -5
This is typically pale red or dusty green, with some change of shade. Generally none of the orbs and scallops seen in Royal Imperial. This year I saw a lot of bright pink and neon green Imperial at the Central Oregon pow-wow's And it even has some hills!
Post by Titania on Jul 18, 2008 7:26:28 GMT -5
Ooh, that's purdy! I love the pink/green combo.
I like this thread...would love to see folks post more like it. It really helps to see slabs and learn HOW to ID.
littlejimie
A rolling stone gathers no moss
Post by littlejimie on Jul 18, 2008 18:26:33 GMT -5
What the differnce from royal imperial jasper vs royal jasper? confused.
Jim
Post by deb193redux on Jul 18, 2008 18:43:39 GMT -5
just my shorthand. There is Imperial and Royal Imperial. The later is often in smallor medium white skinned nodules with stacked orbs, but some are washed out. The non-royal tends to be larger and have white on top or bottom. I do not know if it is large broken nodules or more of a seam jasper.
Post by sitnwrap on Jul 18, 2008 19:45:56 GMT -5
The green in that slab is incredable! Thanks for the info on the difference between the two. A while back my bead supplier told me that the imperial was no longer being mined and they could not get any more. Shortly after, the Royal Imperial shows up. I figured it was the same material but with a slightly different name to generate more interest. Whatever. The material is beautiful
