Terry664
Member since March 2005
Post by Terry664 on Sept 1, 2008 20:52:24 GMT -5
These are a few stones out of my last batch, they are all local from Lake Huron, 3 are Granite, not sure about others but beautiful to work and take a great shine, it shine is better than picture shows. What I wanted to show thought is a new technique I tried. On the stone with the moon and yeng and yang, I used a temporary body tatoo, using same instructions as for body I transfered it to rock, let it dry then covered with a sealer, glue, and finish I use for Decopage (sp) to try to keep from fading. Hope you like thanks for looking. Terry
181lizard
Still lurking :)
Member since December 2005
Post by 181lizard on Sept 1, 2008 21:54:13 GMT -5
You CLEVER man!!! That turned out great!
ejs
Member since July 2008
Post by ejs on Sept 1, 2008 22:05:54 GMT -5
I like the Michigan one! Good job.
rollingstone
Member since July 2009
Post by rollingstone on Sept 2, 2008 0:55:18 GMT -5
Your new technique looks to be wonderfully successful -- good idea!! -Don
SteveHolmes
Post by SteveHolmes on Sept 2, 2008 19:18:58 GMT -5
Ingenious TerrY! I would have thought it would've rubbed off during the tumbling....even with the sealant on. I guess not...huh. Great idea and appreciate you sharing the results with us. Steve
Post by sitnwrap on Sept 2, 2008 20:07:57 GMT -5
That is one great design from an awesome idea. I can see tatooed rocks as the next hot item. If you tatoo, you should put some on display in your shop. I bet people getting a tatoo would by the same tatoo on a rock.
Terry664
Post by Terry664 on Sept 2, 2008 20:21:07 GMT -5
It would rub off with tumbling, I polished a bunch of slabs then applied the tatoo, then sealed it , hopefully to cut down on chance of it wearing away, I still don't know if it will work or for how long I just did it yesterday. Terry
karenfh
Member since November 2006
Post by karenfh on Sept 2, 2008 22:10:21 GMT -5
Cool idea! Always amazed at the ingenuity here!
Shelbeeray
Member since January 2006
Post by Shelbeeray on Sept 3, 2008 21:49:08 GMT -5
OMG too funny - I just did something similar with friends this weekend! I found that you can print your own transfers on transparency film (get the cheap kind, not the kind intended for inkjet printers). Put the transparency in the tray of your inkjet - yes, you are going to print on the slippery side. Set the printer to it's highest ink setting - i.e. best. Print, let dry (never really dries completely). Then very carefully place face down on your stone - don't allow it to move or it'll smear. Then rub it onto the rock - WORKS GREAT! Then, as you did, coat with urethane or epoxy. BTW the second from the left on the bottom row looks like a feldspar porphyry - I love them because they are so graphic and usually take a good shine - especially when done on the wheel.
karenfh
Post by karenfh on Sept 4, 2008 3:51:55 GMT -5
What a hoot, and what in inspiration. Thanks!
Terry664
Post by Terry664 on Sept 4, 2008 5:59:32 GMT -5
That is funny, because yesterday I was wondering if that could be done, now I know, but it sounds like more work, the tatoo is very easy, only trouble with tatoos is finding one that will fit rock, and one you want. I also use stickers as a template, place on slab before tumbling just cut around sticker, instead of having to draw or trace, I do that with tatoo also put image on rock, cut image out then tumble. Terry
Post by creativeminded on Sept 4, 2008 8:29:09 GMT -5
Never thought about using something like a temporary tattoo, I bet that would work on a ceramic piece as well. Love it. Tami
