ejs
Member since July 2008
Post by ejs on Sept 18, 2008 10:09:58 GMT -5
It is slowly dawning on me that one important quality control lesson is to avoid combining rocks with different tumbling properties into a single batch. I am thus striving to run as many homogenous tumbles as I can all the way through.
Is there a master list somewhere of which kinds of rock are safe to combine with each other? For example, is it safe to combine any kind of jasper - to run, for example, a single tumble barrel that contains ocean jasper, red jasper and dessert jasper mixed together? Are all kinds of agate allright to combine into a single tumble (say, Queensland agate combined with Mexican crazy lace agate in the same barrel)? Can PetWood be safely combined with either/both of these?
It would be cool to have a list of groups of rocks that are all safe to combine. For example, if I am going to tumble some quartz, it would be nice to know what else I can safely put in there (citrine?). Of course there will be minor variations (i.e. some variation in the hardness of different jaspers) but it would be nice to have a general formula. Any help?
As always, I am most grateful for the shared wisdom of everyone here!
lynskyn1970
Member since August 2008
Post by lynskyn1970 on Sept 18, 2008 15:12:49 GMT -5
well i usually follow a general rule to just mix rocks of or about the same hardness together. i'm not sure if there is a master list of sorts but from my experience from tumbling many, many batches of stone i just make sure that the hardness is about the same. i have tumbled assorted agate and jaspers in the same batch with great success. i have even tumbled a mixture of assorted stuff including obsidian, jaspers, agates, pet wood with great results. so my thought would be just make sure the hardess of the stones are aproximate to each other. i see no reason why you cannot combine different types of jaspers and agates together in one batch even the quartz. i have had no problems in doing so.
ejs
Post by ejs on Sept 18, 2008 15:52:49 GMT -5
Post by akansan on Sept 18, 2008 16:20:04 GMT -5
For the most part, anything 7 and above can tumble well together. So if it can't be scratched with a quartz point, you should be safe throwing it in the barrel together. There are, of course, some qualifications. Some stones are more apt to fracture (there's a reason some people here call amethyst the devil rock) than others and require more babying. You also have to be careful of the name - just because it's named jasper doesn't mean it's actually a hard jasper. Leopardskin Jasper - a rhyolite. Picasso Jasper - so not a jasper! I don't think there's a master list of tumble-buddies.
Post by stefan on Sept 19, 2008 12:50:49 GMT -5
I rough grind everything together- that really plays out the softer or unsuitable rocks- if it survives the rough grind (and trust me- many don't) then I'm usually good to go- I will occasionally take a venture with softer material (sodalite, linestone, fedspars, obsidians ect.) but I usually stick to the Quartz based (Chert, Jasper, Flint, Agate, chalcodony) material as this can be run together with miniumum worries.
