DeanW
Member since December 2007
Post by DeanW on Oct 10, 2008 21:52:23 GMT -5
So, what is the "best" way to get the oil out/off of pieces after taking them out of the slab saw. I've tried a couple of things and am not too pleased with the results so far.
I've always heard before that kitty litter (old style non-clumping) works great, but doesn't seem to be so for me. I've also been dropping the pieces into a 5-gallon bucket with liquid soap (Dawn) and water. This seems to be working a little better, but not fast enough for me. Am I being to impatient or ?
Dean
goofie1
Member since June 2006
Post by goofie1 on Oct 10, 2008 22:25:14 GMT -5
i have used simple green, that seems to work. ralph and mary ann
Post by bobby1 on Oct 10, 2008 22:37:16 GMT -5
I've always just used the plain old cheapie cat litter. You have to move the slab around a bit to get good contact with the litter. Leave it in the litter ovrnight and you should be happy with the results. Bob
Post by johnjsgems on Oct 10, 2008 22:40:22 GMT -5
I combine both. A day or two in the cheapest kitty litter I can find then overnight in a good degreasing detergent like Simple Green.
Post by Tweetiepy on Oct 10, 2008 23:02:19 GMT -5
The rock shop uses kitty litter - works great
Wolfden
Member since November 2007
Post by Wolfden on Oct 11, 2008 11:42:08 GMT -5
How does the litter work ? do you just cover the slabs in it ?
Thanks Dennis
Post by stonesthatrock on Oct 11, 2008 12:39:10 GMT -5
heres what ralph made and filled it up with kitty litter. Just bury the slabs in there while your cutting more. I use it everyday......all day lol
Post by bobby1 on Oct 11, 2008 14:50:45 GMT -5
One precaution: Keep litter pan away from cats or else.......... Bob
Post by Bikerrandy on Oct 11, 2008 16:53:54 GMT -5
I use Dawn, hot water and a tooth brush. I drip some dawn straight onto the slab, scrub it around with the tooth brush, and continue to scrub while I'm wrinsing it off with hot water.
spicer m
Member since October 2008
Post by spicer m on Oct 11, 2008 22:23:52 GMT -5
I use ASOME, Comes in 20oz bottle at most any dollar store for a dollar. also some have it in gallon jugs. You can dilute it like simple green. I use it to degrease my truck engine, be carfull it will dull paint if put on full strength.
DeanW
Post by DeanW on Oct 11, 2008 22:30:30 GMT -5
Thanks for all the replies folks. Sounds like I need more litter. Tony (catmandewe) I'm hoping you'll chime in also.
agatemaggot
Member since August 2006
Post by agatemaggot on Oct 12, 2008 21:11:10 GMT -5
We leave our slabs in kitty litter overnight and then soak in mean green or fast orange for several hours. You can scrub with a vegetable brush under running water to remove any residue .
Harley
agatemaggot
Post by agatemaggot on Oct 12, 2008 21:18:55 GMT -5
I forgot the keep the pan ( OFF ) the floor part. This is a VERRRRRRY important bit of information if your wife happens to have a cat ( or ) a pet hedge Hog.
Post by catmandewe on Oct 12, 2008 22:38:30 GMT -5
I don't know if this is the right way or not, but I throw all my slabs into a 5 gal bucket with soapy water, (of course after a few days it becomes oily water.) Then when it gets too full, or I get some time, I pour all the oil and water out, refill the bucket with soapy water, then I take the slabs out and put them in the kitchen sink and get a scrubber and scrub them under hot water, this takes all the oil and sludge off. Then, and this is very important..................you lay all the slabs out on a table and take pictures, so we can see what you are cutting. The slabs have then been properly degreased...........................Tony
DeanW
Post by DeanW on Oct 13, 2008 0:10:59 GMT -5
Thanks Tony. I am trying to photo stuff before it gets attacked by my wife but lately she's been polishing faster than I can cut lol. We have a show this coming weekend soooooo.
knapper42
Member since March 2008
Post by knapper42 on Oct 13, 2008 20:53:58 GMT -5
I keep a plastic pan next to my saws with about 1/2 inch of degreaser in it and let the slab soak until the next slab comes off. After soaking in the degreaser I put the slab in a pan of kitty litter to dry. I heat treat most of my slabs for flintknapping. If the slabs weren't clean I would have a real problem with smell and smoke from any residue.
oldgrouchy
Post by oldgrouchy on Oct 15, 2008 18:46:36 GMT -5
I guess I am cheaper than most, BUT I buy 50 lb. bags of oil dry from Sam's Club for a few bucks and use it to soak up the oil. Much cheaper than cat litter and actually works better-in my opinion. I salvaged an old 9X12 pan from my cast off cookware and fill it 3/4 full so I can bury the slabs in it. The next day they get washed off in a bucket with dishwashing detergent and warm water and they do not smell or show oil.
DeanW
Post by DeanW on Oct 24, 2008 0:43:05 GMT -5
All great tips. Thanks.
