Digforcrystals
Member since July 2008
Post by Digforcrystals on Oct 15, 2008 18:43:04 GMT -5
Any recommendations on where to get one ? Thanks in advance . Rodney
Post by Woodyrock on Oct 16, 2008 1:50:50 GMT -5
I use a firebrick, they are cheap, and easy to find at fireplace stores. I think the one inch thick bricks are a dollar. Woody
darrad
Member since September 2006
Post by darrad on Oct 16, 2008 19:42:53 GMT -5
I use a fire brick as well. $1.99 at the local masonary supply yard. 2 3/4 thick. One slice and it's ready to go. Obsidian also works to an extent but I find I still need to use the brick a couple of times through out the blades life. PM John at Johnjsgems about the dressing stick.
Digforcrystals
Post by Digforcrystals on Oct 16, 2008 20:17:35 GMT -5
thanks ! I just got my WESTERN LAPIDARY saw going today . 18" saw that is 40 years old . It came with a blade from lopacki . It cuts the softer stuff fast but prior to buying it , the blade wouldnt cut agate . It being new , something is wrong . It also came with a 303 blade in a box. I was told it was good and I can see diamond showing in the brass of the 303 . So at some point I will put the 303 back on . But I do know that there had to be a reason that the 303 was taken off and a new blade put on I do have some obsidian on hand and will try that before trying some more agate . I really am not sure where to get fire brick locally ?
Post by akansan on Oct 17, 2008 8:38:56 GMT -5
If you're still wanting a dressing stick, I know John at JSGems sells them. Box of fire bricks can normally be purchased at DIY places or farm&home type places. I can buy a box of 12 firebricks at our Orscheln's for about $7.00
Digforcrystals
Post by Digforcrystals on Oct 17, 2008 8:58:34 GMT -5
Thanks , I am ordering a dressing stick from John at JSgems . I'll also look into getting a peice of the firebrick just to try it out .
Wolfden
Member since November 2007
Post by Wolfden on Oct 17, 2008 12:19:20 GMT -5
Home Depot or any local hardware store should have or can tell you where to get firebrick
I also just got a 18" saw mine is a Raytech thu . I got an extra blade with mine but I dont know who made the blades. Did you or can you put up a picture of yours ? I'm curious about the differences
Thanks Dennis
