Rogue Trader
"Don't cry because you are leaving, smile because you were there."
Member since December 2008
Post by Rogue Trader on Nov 14, 2008 18:02:50 GMT -5
I've read several posts, forums, boards and web sites relating to thickening agents to assist in the transfer of grit to rocks.
Ranging from sugar, honey, wallpaper paste, corn starch, ect ect.
One method I use to assist in making a fast slurry is to included a softer rock to my tumbling barrel. (I only tumble.)
When tumbling rocks of hardness 8 - 9 I also include a few scrap pieces of malachite in the barrel as this breaks down much faster and turns a thick slurry in only 2 days.
Post by connrock on Nov 15, 2008 7:03:37 GMT -5
Rogue, Good tips!!!
Thanks
connrock
docharber
Member since October 2008
Post by docharber on Nov 15, 2008 15:27:14 GMT -5
Let me suggest something- bulk laxative agents with nonfermentable fiber like Citrucel. They won't ferment like the other materials often used and so won't make gas just as they don't make gas in people. This could be a little costly, but it it wouldn't take much. You might try chopped up disposable diapers as they contain a water binding polymer which I understand is fiber-like. Sawdust might be a good choic, too. I would use good white hardwood as softwoods and oak might contain resins or tannins that could atain or etch the stones. Mark H.
Roan
Member since January 2008
Post by Roan on Nov 17, 2008 16:35:08 GMT -5
Malachite = copper, not really something I want to break down in my barrel(s). Personally I'd rather use small pieces of soapstone (talc), which will break down just as well or you can pulverize it into small bits yourself. Or marble, which is also soft. You can get a piece of marble tile pretty cheap at Home Depot or Lowes or Home Hardware (for the Canucks).
Eileen
Saskrock
Member since October 2007
Post by Saskrock on Nov 17, 2008 23:46:38 GMT -5
Ok I have to ask it. Why wouldn't you want copper in a tumbler??? What does it do?
Rogue Trader
Post by Rogue Trader on Nov 18, 2008 3:53:09 GMT -5
Ok I have to ask it. Why wouldn't you want copper in a tumbler??? What does it do? Yes, I have to ask the same question. I see no reason to NOT add malachite, afterall I have tumbled a complete batch of malachite in the past. Thats when I found it make a nice thick goo thickener.
Roan
Post by Roan on Nov 18, 2008 8:01:56 GMT -5
Because it's toxic and I pour my slurry out in the backyard.
Post by Hard Rock Cafe on Nov 18, 2008 8:57:16 GMT -5
Wow, I never knew copper was toxic. I just read the wikipedia entry, too.
So, then I began to wonder, do our copper pipes shed? It turns out they can if the water is acidic.
Now, what about all those pennies?
But I guess I'm in a wondering mood today. No doubt someone will chime in with their positive experience with slurry thickeners, but it seems to me it wouldn't make much difference. Assuming you don't have too much water, if the grinding action is caused by grit becoming trapped between two stones, then the slurry thickness (viscosity) shouldn't make much difference at all (and it could conceivably slow things down if it creates too much cushion). I have a hard time envisioning much grinding going on from the grit/slurry running on a bare stone face.
I think I'll just let my rocks continue to thicken up the slurry on their own...
Post by Jack, lapidaryrough on Nov 18, 2008 10:35:53 GMT -5
No doubt someone will chime in with their positive experience with slurry thickeners, but it seems to me it wouldn't make much difference""
The best thickener, Is Corn Starch.
Jack
ace
Member since August 2008
Post by ace on Nov 18, 2008 11:39:19 GMT -5
Most metals, like copper can be toxic in high enough doses. Its not as toxic as for instance lead or mercury though. The problem with metal poisoning is, it tends to build up over time. So I would suggest using latex/vinyl gloves if you are handling the copper in the slurry.
From my understanding, you do not have to worry about the copper in your pipes, in that what minute amount that may dissolve into the water, is safe. However, there can be problems in older homes with the lead in the solder used to seal copper pipes. Plumbers now use a lead free solder which is supposed to be safer.
Roan
Post by Roan on Nov 18, 2008 19:00:00 GMT -5
Wow, I never knew copper was toxic. I just read the wikipedia entry, too. So, then I began to wonder, do our copper pipes shed? It turns out they can if the water is acidic. Now, what about all those pennies? . . . Yep, it is. Reason I know this is because I keep aquarium fish Although it's not something I would put in my own tanks, copper sulfate is often used to kill fish parasites. The reason I won't use it is because of the accumulation. It gets right into everything (glass silicone and all) and you can't remove it. Nuh-uh. Most people do not have acidic water as the water companies add phosphates et al to the water to increase buffering. Some do, though. When it doubt, test it. My understanding is that a lot of turquoise and malachite jewelry is "backed" to keep it off the skin because of the copper content. As for pennies -- don't put them in your mouth Eileen
Post by Hard Rock Cafe on Nov 19, 2008 12:45:59 GMT -5
Great, now we have to be careful about which rocks we lick... :-)
Roan
Post by Roan on Nov 19, 2008 18:56:37 GMT -5
Great, now we have to be careful about which rocks we lick... :-) Chuck If you're licking your rocks, you're doing it wrong
drjo
Honduran Opal & DIY Nut
Post by drjo on Nov 19, 2008 19:47:34 GMT -5
But well articulated .
docharber
Post by docharber on Nov 20, 2008 13:52:29 GMT -5
I still think bulk laxatives would would well (nonfermentable. About copper- Here;s the story. Yes, it is toxic. So is iron in excess or almost any of the common metals. Cobalt compounds have been linked to heart failure when used to maintain the head on beer (incident in Canada many years ago). Chromates are known carcinogens when inhaled. Maybe not when ingested from the "health food" stores. It's all a matter of the form the copper is in and its solubility. Metallic copper is fairly insoluble, especially in alkaline, hard waterost of us have. Stomach acid can alter the composition of otherwise harmles compounds and make then into soluble, toxic compounds. So, don't eat the malachite (copper carbonate). Copper sulfate is much less inert. Trace amounts of copper are needed in our diet, excess copper deposition in tissues (as in a metabolic disorder, Wilson's disease) leads to cirrhosis and liver failure and neurotoxicity among other problems. Iron overload seen with hemachromatosis can have some of the same outcomes, plus diabetes. Children ingesting excessive iron sulfate (iron/vitamin preparations) can be seriously poisoned. Metallic copper is not particularly toxic but if you cook green beans with a little salt in a copper pan with a worn lining as I once did, your in for a nasty surprise. Major cramps, vomiting and diarrhea. I can still taste it after 25 years. Lead and mercury compounds are usually more stable and thus less bioavailable than copper. So, you get more chronic poisoning problems from slow delivery into the body than with iron or copper where the toxicity can be very acute. Copper is used as a fungicde and wood treatment in sulfate form. COpper and iron compounds can both stain in contact with the skin and that is why contact with the skin is to be avoided, not toxicity. Turquopise is a copper aluminum phosphate and not very soluble so not really that toxic in the environment. Gee I wish I had enough malachite to thicken my slurry. Of course , for the holidays you can throw in rhodochrosite scraps (manganese carbonate) and have green and red slurry to dump in your yard. How festive! Eileen has a good idea about the soapstone. It is nonacidic, nontoxic, grinds away quickly, won't sstain the rocks like malachite might, and its cheap. Mark H.
lsmike
Maxwell's demon lowers tumbling entropy
Member since January 2007
Post by lsmike on Nov 24, 2008 18:43:17 GMT -5
In a rotory tumbler any source of cellulous works great- sawdust or just some ripped newspaper.I do it in all my rotary loads.Mike.
rockdewd
Post by rockdewd on Nov 27, 2008 23:30:51 GMT -5
>>My understanding is that a lot of turquoise and malachite jewelry is "backed" to keep it off the skin because of the copper content.<<
The practice of backing turquoise with metal epoxy like Devcon is to get back the weight of the stone removed cutting and polishing. It's just the way most turquoise cutters look at it. When you are buying turquoise cabs check to see how thick the backing is and think how much Devcon you are getting opposed to turquoise. Some turquoise cabs are paper thin turquoise and up tp 3/16" backing. Once the stone is set in a bezel it's impossible to see how much of it is Devcon and how much is turquoise. It's been a scam going on for decades. Myself, if I back turquoise I use a paper thin layer of JB Weld. It keeps the edges of the cab from chipping and strengthens the stone without so much weight.
Rick
rockdewd
Post by rockdewd on Nov 27, 2008 23:30:54 GMT -5
P.S. I prefer to use small chunks of marble from tile and countertops. It produces a niece thick slurry within a couple days and cuts down on gas build up.
Rick
docharber
Post by docharber on Dec 4, 2008 17:39:36 GMT -5
Thanks, RIck- good advice about fraudulent practices. I love JB Weld, by the way, and have used it for a variety of purposes. . Malachite and turquoise will, I understand, stain skin in some cases and i was under the impression that was why they were backed or coated. Mark H.
