rocker1974
Member since November 2008
Post by rocker1974 on Nov 21, 2008 19:07:19 GMT -5
P.S. - The rock hardness is hard enough that only diamond coated blade, and diamond coated grinder, polishing tips worked. Other tips just got very hot, and chipped apart , bent, broke, or covered my stones in a metallic film, which might I add is a pain to get off, requires further grinding. This is my first cab. I have an idea of what it is, however, since I personally collected rocks from the locality, which is not well known to many, I'd rather ask the experts to find out what else it could be. Thanks, Aaron
88pathoffroad
Oregon ROCKS!
Member since August 2008
Post by 88pathoffroad on Nov 22, 2008 21:55:33 GMT -5
Could be diamond! Where'd it come from? Any type localities in that area? Test it for hardness, streak, acid resistance? Does it fluoresce?
rocker1974
Post by rocker1974 on Nov 23, 2008 13:58:43 GMT -5
Hmmm, no diamond localities close by here in Washington. I'm fairly certain it is not hard enough to be diamond. It is probably between 6.5 to 7.5 in mohs hardness. A guestimate based on other rocks I am cutting. Somebody guessed Agate, however, it does not in my uneducated opinion look like it is quartz based. I guessed it was Jade, but frankly I wanted it to be jade because I jade hunt in a locality that has alot of jade, and I know how to find the green jade, however, I am lost as to how to identify white, red, yellow, or brown gem quality jade. I am attaching two more images of which are the rock it came from. The black stripes are actually silvery metallic dust mixed with the white. When cut the metallic stuff/shine shows. When cutting the dust is white. The blacker stripes are metallic gray/dark gray dust which also can contain metallic film (maybe iron or nickel - a high nickel content area which makes the green jade green). There is some quartz in the locality, however, it is fairly easy to identify by eye, and I have never seen the quartz in the area do what this stone does. Attached are some images for further assistance: Some of the stripes are actually transparent and clear: The square cut rock in the back:
