Rogue Trader
"Don't cry because you are leaving, smile because you were there."
Member since December 2008
Post by Rogue Trader on Nov 22, 2008 13:59:13 GMT -5
I'm going to progress this hobby now and i'm going to have a go at cutting and shaping some of the rocks. I have a tile saw, which I guess is OK for cutting the rocks, but, and this is the clincher question, is a general purpose bench grinder with course and medium discs suitable? Such as this one here img.en.china.cn/0/0,0,59,16480,370,370,0d5bc00b.jpg
Post by bobby1 on Nov 22, 2008 14:47:04 GMT -5
These metal grinders are usually set up to run at 3450 rpm, which is about twice as fast as they should spin. Most of the lapidary wheels are designed to run at 1725 rpm. Bob
Post by Bikerrandy on Nov 22, 2008 21:03:06 GMT -5
If you can find a bench grinder that runs around 1750 rpms, you can. (I have one). You'll need a silicon carbide wheel that's made specifically for lapidary use, they can be purchased for around $25 online.
Post by Bikerrandy on Nov 22, 2008 21:09:19 GMT -5
Oh, one more thing....wear a respirator!!
