Post by sandsman1 on Aug 18, 2005 12:34:29 GMT -5
yea i still have the board that was strapped to it when they shipped it that might be the place to start then try and foam it in some way ill be thinkin bout this one hahaha any other ideas yell um out anybody
Post by stefan on Aug 18, 2005 12:46:02 GMT -5
SEND ME THE GENIE- save your back! I was thinking if you get a trailer with an extra bed- you could strap to the bed?
Post by sandsman1 on Aug 22, 2005 13:33:24 GMT -5
thats a good idea stefan both trailers i liked had queen size beds in the frount maybe i can just strapit to the bed when im gonna be movin they both had thick pads on them i bet that would doit
llanago
Member since January 2004
Post by llanago on Aug 22, 2005 17:14:47 GMT -5
Hey Sands, that is a great looking truck and you will love it. I have a V10 250 superduty and it pulls my 36' 5th wheel like a dream. The 250's are real work hogs. I even get pretty good gas mileage when not pulling - 16 or MPG and about 10 when hauling the RV.
The 5th wheels are really nice - offer a bit more room than a pull trailer and are much more stable on the road and easier to back believe it or not. Heck, my 36' 5th wheel is easier to pull and back than the horse trailer I use to have. Don't skimp on a hitch either. If you get a pull behind, you really need to buy stablizers for your hitch. If you decide on a 5th wheel and and if your truck is a shortbed, like mine, you have to spend a few extra bucks for a "slider" hitch that prevents the 5th wheel from slamming into the back of the cab when turning corners. If you have a short bed and go for a 5th wheel DO NOT let anyone talk you out of buying a "slider" They are more expensive, but not near as expensive as fixing the truck after you turn that first corner and the 5th wheel slams into the cab.
And, DON'T YOU DARE go to Florida without coming through Texas and seeing me and BE. Hell, who knows, I might hitch up the 5th wheel and go with ya'!
As far as that goes, you could pack up that new truck and head down here and buy a trailer. You could probably save a bit buying one down here because everything here is less expensive than in the northeast. AND you would save a bunch of gas by not pulling a RV across the country. And, with the cost of gas these days, every little bit helps. I filled up yesterday - cost me $51.35 and I wasn't even completely empty!!
Well, gotta go get to work on the fllight cage I am building for my two new babies - Izzy and Gizmo, the cockatiels.
Post by cookie3rocks on Aug 22, 2005 17:42:45 GMT -5
Well, speaking of "I"m still Kicking"... Howdy LLana, we've been wondering about you as well! How YOU doin'?
cookie
Post by stefan on Aug 22, 2005 19:41:36 GMT -5
Sands Llana is right about the 5th wheel- but you lose the ability to put a cap on the truck when hauling! We have friends who had a shortbed 250 and the were talked out of the slider hitch- guess what? Yup almost $4000 in damage (they said screw it and bought a 350 dually longbed!) If you get a pull behind get the Reese Cam action weight distribution hitch with the Cam Action sway bars! mine was almost $600 installed but I can pull that trailer at 65 MPH and have a semi pass me and it don't move an inch- They tried to sell me a friction sway contol but I talked to some who had em and they said they really are touchy and don't work as well- You may not need the weight dist- but they do save wear and tear on the truck drivetrain and shocks (course those Frod Super Duties are brutes when it come to hauling!)
llanago
Post by llanago on Aug 22, 2005 21:48:06 GMT -5
Hey Cookie, I'm doin' fine. Just have more projects goin' than time and energy to do them.
Stefan, the first time I turned a corner and saw that big honker 5th wheel getting closer and closer to the cab, I nearly stoked out. Even though I knew the hitch would slide back to make room it was still scary as hell.
Longbed pickups are pretty hard to come by these days around here - unless you are at the dealership when they roll them off the delivery trucks. The farmers and ranchers snap them right up.
I have a PullRite SuperGlide - they are way superior to any other glider. Mine will pull 20,000 lbs. and new costs $2800.00 new three years ago. I got lucky and found a used one for $1200 - with shipping and installation it ended up costing about $1800. Still way more expensive than other gliders, but well worth it. Don't have to constantly get out and set the glider to slide as with the other gliders. Also the way the hitch is built makes it impossible for the 5th wheel to drop down off the hitch slam through the pickup bed. You set the jacks at the right level, then back onto the ball, and the closing mechanism locks around the ball, then you pull the RV legs up. Know lots of folks that torn up the bed of the pickup raising the jacks, only to have the RV slide off the hitch. Impossible with the PullRite. Now, backing on to the ball just right to lock the mechanism is a whole 'nother story!
Post by rockyraccoon on Aug 22, 2005 22:42:09 GMT -5
llana so good to see you on the board again. don't take such long breaks! how is barbara?
kim
MichiganRocks
"I wasn't born to follow."
Member since April 2007
Post by MichiganRocks on Aug 23, 2005 0:21:56 GMT -5
Hey John, Llana right about the PullRite. I've had RVs of some sort all my life. Used to belong to NCHA and then FCRV also. I think that the PullRite hitch is the best ever made. Even if you go with a conventional trailer, PullRite makes a hitch that is far superior to anything else out there. Of course you have to pay for it! They are expensive, but it won't take you long to realize that they were worth every penny.
Ron
Post by stefan on Aug 23, 2005 9:08:50 GMT -5
Does Pull Rite make a weight distributing anti sway hitch? I've seen there 5th wheels hitches but never anything else- Course with the price of gas and all I think next year I'll be parking the 36 ft trailer in one site for the whole year- that 1 ton chevy I have (454 4 barrel with 4/10 gears) just ain't easy on gas! (8 MPG towing)
Post by sandsman1 on Aug 25, 2005 9:25:30 GMT -5
hey llana im glad you seen this and replyed i know you said you had a big trailor and i wanted to see what you had to say too stefan has been giving me some pointers and im thankfull for that cause i have no idea what im doin hahaha and it aint the first time hahahaha i have a long bed super duty and i just got a used cap for the back it dont fit perfect but its in good shape and its fiber glass i only paid 200.00 when i went lookin for one new the guy told me at the place it would be around 900.00 for an aluminum one new and i realy wanted a fiberglass cap so i knew it was time to start callin friends hahaha and i found a buddy and his brother had one sittin in the yard so i went to philly yesterday and got it the bed on the superduty are wierd shaped and the part right behind the cab is wider then the back end of the bed so it sits alittle wierd but for the price i can live with it haha--- now ya got me thinkin about loadin everything in the back and makin a run down for a better deal on a trailor look here i was gonna go get this next week if i cant find a better deal it looks new inside i was in it and the side slides out for a wider room i was thinkin that would be better cause i thought about takin out the couch and gettin someone to build me a bench for my genie in the spot take a look and tell me if there goin cheaper there cause this one is spotless inside www.crossroadstrailers.com/database/inventory_item.asp?id=208844
Post by stefan on Aug 25, 2005 9:42:24 GMT -5
Looks sweet to me- Not sure If you can get a cheaper price (not around here- maybe down South? Onlt thing is the fabric and decor is very light in color- and will show any dirt very quickly! You want to check the couch out carefully- Often times the are built into the the trailer structure (they will have storage underneath) and can be a real pain to move out- It actually might be easier to build the work station where the dinnette is!
Post by sandsman1 on Aug 25, 2005 9:52:03 GMT -5
i made the guy pull it up so i could get a look at it and theres only 4 bolts holding it to two short legs comming from the floor so it should be easy it lays flat fo an extra bed but its just me so i dont need it --- but your right about the color i realy dont like green hahaha and it is kinda light colored for grinding in hahaha id have to cover everything around it to keep it nice but ill do what i gotta
Post by sandsman1 on Aug 25, 2005 9:56:29 GMT -5
hey llana what does your trailor weigh i was worryin about pullin 6700 lb will this truck do the job and not burn up maybe ill get a bigger trailor hahaha this way ill have more room for rock stuff in the trailor i was gonna leave my saws in the truck bed and use a table when i need them i didnt want the mess inside the trailor
Post by stefan on Aug 25, 2005 10:27:45 GMT -5
Sands- You should be able to pull something like 12,000 Lbs with that truck- Them SuperDuties are Pullin machines!
Post by sandsman1 on Aug 25, 2005 10:43:46 GMT -5
wow realy see i thought you had to add the weight of the truck to the total see i have no idea whats goin on hahaha so dont hesatate yellin something out ---- i can use all the help i can get hahaha--- cause i drove up to look at trailers and the guy says you not gonna use that to pull one of these are ya in (my 4-runner) and i sid yea he said ill tell ya right now dont you will burn it up goin across country it might work for a short haul but id get a bigger truck so i went for this one
llanago
Post by llanago on Aug 31, 2005 21:58:55 GMT -5
Sands, is your truck a V8 or a V10? The V10 will haul 16,000 lbs. If I remember correctly from when I was RV lookin', a V8 will haul about 13,000lbs. Of course, that is total weight. The weight of the trailer and it's contents AND the weight of the truck and it's contents. I am WAY overweight, but since I can't afford the gas to haul this big honker anywhere, it's not a problem.
I am thinking there will be a lot of good deals on RV's in the next couple of months because of the gas prices and the economy across the board. With 95% of the Gulf refining capability destroyed or seriously damaged, and the loss of anywhere from 400 to 600 drilling platforms in the Gulf, gas is going to go sky high. Katrina destroyed more than houses along the Gulf Coast and it's going to seriously effect the economy everywhere.
If I were you, I would decide where I want to go and settle for a while and start checking into RV prices there. Hauling one across country getting 8 to 10 MPG is gonna cost a small fortune.
llana
Post by stefan on Sept 1, 2005 9:00:49 GMT -5
MY friends just traded in there 350 diesel for another 350 deisel- He told me that freaking thing (a 2006) can haul 35,000 LBS!!!! I guess Ford up the engine output on all there superduties- What year was your truck? Yea Gas is no longer the take fro granted item anymore- We are going to look at a permenate site this weekend- and if all works out I will probably end up selling the truck- I talked to my local RV guy- and he pointed out that the price of everything is going up and that RVing is still gonna be the cheaper way to go! But He also said that used RV prices are gonna fall thru the basement so Sands- if you can wait a couple weeks and see what happens!
Post by sandsman1 on Sept 2, 2005 14:48:17 GMT -5
llana its a v8 5.4 it seams strong and it even has a temp guage for the tranny so im thinkin it can do some pullin and its a 2003 with 56 thousand on it so im thinkin it aint beatup bad yet hahaha i said yet maybe after i get done with it.,, i been tryin to hold out for after labor day cause thats when most people trade in or sell there trailors here ,, so in the next couple weeks ill start lookin again i still like the layout on the one i posted so i might go back and do some hagelin and see what i can get it for
Post by stefan on Sept 6, 2005 13:08:26 GMT -5
Keep us posted! I checked on my permnanat site this weekend- They are opening up a few more sites so I got a good chance! man the trailer for sale here was un believable- Guess they have a dozen people upgrading to larger trailers- course when a trailer sits on a seasonal site for a few years- they tend to develop a lot of leaks when you start to haul em!
