Rogue Trader
"Don't cry because you are leaving, smile because you were there."
Member since December 2008
Post by Rogue Trader on Dec 10, 2008 3:33:19 GMT -5
I'm not likely to ever make one, but I'm sure many will be progressing that way, so:
What covering do you use on Carpet wheels?
Are they natural fibre carpets - Wool, Jute Sisal, or are they man made fibres - Polyester, Acrylic, Nylon?
Has anyone carried out a survey to test which fibres give the best results?
Post by connrock on Dec 10, 2008 7:08:54 GMT -5
Did I miss something here??
What do you use carpet wheels for?
connrock
Post by bobby1 on Dec 10, 2008 10:06:10 GMT -5
I use a carpet wheel for about 95% of my cabochon polishing. I have never tested differing types of carpet because the one that I use works so well for me. I use a piece of 1/4" thick standard office carpet and Cerium Oxide. I'm not sure exactly what the fiber is other than it is synthetic. I have been using this material for maybe 25+ years. Bob
Post by johnjsgems on Dec 10, 2008 10:48:12 GMT -5
I've used scraps of nylon carpet on sphere cups and they worked fine. If you have a choice I would think wool would work best as felt buffs generally outperform other buff materials. The biggest problem people have when making their own polish wheels are getting them balanced so they don't vibrate excessively rather than what material they cover them with.
Post by bobby1 on Dec 10, 2008 11:24:15 GMT -5
My wheel is about 14" in diameter and it runs at about 350 rpm so balance hasn't been much of a problem. Bob
Post by connrock on Dec 10, 2008 14:44:45 GMT -5
Duhhhh,,,
I'm thinking of wheels on a chair going across the living room carpet!! LOL
Oh well,,,,some days,,,,,,ya know?
connrock
navi
Member since November 2008
Post by navi on Dec 10, 2008 19:49:58 GMT -5
connrock, the term would be casters, not carpet wheel!!! :-)
docharber
Member since October 2008
Post by docharber on Dec 14, 2008 14:00:17 GMT -5
I've seen self=stick indoor-outdoorr carpet tiles used. They have a thin cushion backing and low pile so they don't soak up a lot of abrasive. The nylon stuff used in trunk lining might work too.
mark H.
