navi
Member since November 2008
Post by navi on Dec 11, 2008 13:02:07 GMT -5
i collected a bunch of agates recently. they are out of a river, so they have that river worn brown patina on them. after rinsing them, i saw they were well banded. i don't have any acid to clean them farther. i had a weird idea today. i stuck one in a plastic cup with an efferdent tab. didn't clean everything off, but the rock is much easier to see the bands and color, before the tumbling starts.
thought i'd share.
drjo
Honduran Opal & DIY Nut
Post by drjo on Dec 11, 2008 16:32:38 GMT -5
Cool... I've used them for cleaning other stuff but hadn't considered rocks.
I wonder if they could work with any chemicals? (muratic acid, oxalic acid etc.)
Good tip/find!!!
Dr Joe
lsmike
Maxwell's demon lowers tumbling entropy
Member since January 2007
Post by lsmike on Dec 11, 2008 18:12:10 GMT -5
You can also treat them with oil.Mineral oil seems to work best.Just soak them for a day or so-low heat helps too{sunlight o.k.].They will be a little"gunky" but will show better. "Water-washed" rocks can skip the rough tumble and go to 150/220 etc. if you want the best shine.Mike. P.S muriatic acid is a good de-gunker,but I don't consider it worth the hazard.
docharber
Member since October 2008
Post by docharber on Dec 12, 2008 15:04:44 GMT -5
You're trying to remove calcite and limestone encrustations, and muriatic acid (hydrochloric acid) is great for that and safe if diluted properly. But for those nervous about using it, 10% pickling vinegar works just fine, only slower. Mark H.
morticiamonroe
Post by morticiamonroe on Dec 12, 2008 16:13:43 GMT -5
Navi, I'll file that one for future use. Thanks for the tip.
On occasion, using a bit of CLR or something else of that nature works very well also.
