Post by sandsman1 on Jan 13, 2004 20:06:05 GMT -5
hi all anybody know if this will work for grindin some shapes or maybe some cabs i was looking around and seen this great price free ship but will it be any good the way its set up for water only one wheel is wet ok ill wait to see what you all think seeya john store.yahoo.com/brandsplace/0059-bgwd.html
Post by docone31 on Jan 13, 2004 23:32:43 GMT -5
I use the same machine for grinding turquoise, malachite, lapis, and roughing stones for tumbling. Harbor Freight has the same machine for a few dollars less. The 8" wet wheel is very agressive on the copper mineral stones. It works very well to flatten a cabachon. The smaller 6" wheel does a great job on shaping cabachons. You will need a cup of water to cool the stone. I like it.
Post by sandsman1 on Jan 14, 2004 0:50:02 GMT -5
cool thanks again doc im gonna order one this week thanks for your help i was hopin you would see the post i remember you said you have tought some classes and i fig you would know if it was worth gettin john
Post by docone31 on Jan 14, 2004 18:18:21 GMT -5
For doing cabachons and shapes, it is not the best. It will work however. For tumbling you cannot go wrong. Do not add anything to the water side. It foams up and runs all over. I use it without the shields. For serious cabachons the Loretone combination unit is great. Another point, never mix elements. Once you use stone, never again grind metal unless you reface the stone wheel.
Post by sandsman1 on Jan 15, 2004 12:56:47 GMT -5
hey doc im gonna bug ya alittle more is this what you are talkin about #7 on this page - www.alpha-supply.com/211.htm and if it is what is better 6 or 8 inch and which water set up is best for less mess dont wanna drown wile doin some cabs hahaha ok thanks again for your time and smarts on the whole thing its easy to go buy the wrong stuff and have to replace very soon after ---- john
Post by docone31 on Jan 15, 2004 13:35:30 GMT -5
I had to take the page off the pagehttp to get the site. Yes, that is the unit. I like 6" as everything is cheaper. Most folks like the 8" for control of the work. For water feed, mount a 5 gallon bucket above the machine with a thruhull fitting on the bottom. The gravity will make the drip through the petcocks supplied. That one is my favourite. I do have a unit like the one shown in the previous comment I might like to sell. I would let it go for 50$ plus shipping. It does come in handy. It is not lapidary material however. With the loretone, once you have reduced the corundum wheels to zero, replace with diamond. Much much better.
Post by sandsman1 on Jan 19, 2004 23:25:48 GMT -5
hi all hey doc im gonna order that lortone ba-64 on friday can you tell me if the motor bolts right to the arbor or will i need a board to bolt both to i found the same motor and mount for 60 bucks they wanted 129.99 for motor and 12.99 for mount i been shopin haha and did the water lines and valves come with to arbor i see holes in the top of shield but no water lines in that pic and do they take 1-1/2 inch wheels or just 1 inch wow like you got nuttin better to do then answer my questions well i appreciate all your help im sure ill bug you more hahaha thanks again ---john
Post by docone31 on Jan 19, 2004 23:36:34 GMT -5
Many folks have spent countless hours teaching me. It is a little thing to spend time with another person. The unit has an angled mount with four machine screws on the back. It needs a mount for the motor. If you can get the motor and mount for the price you indicated, have at it. There are holes on the top. Mine came with petcocks but time has passed and yours might not. If not, get some petcocks to fit the holes. The tubing you will have to supply. I matched the petcock diameter with the fitting on the bucket. I also use 1 1/2" wheels. I have a diamond 100 grit mounted on the first stage, and an expanding rubber drum on the second. I change belts for the different grits. I also put a leather belt for polishing. It comes with a leather pad and threaded plate for the end wheels, and they are all tied in with that. I replaced the disc with a nut. The rubber drum does the fine work. I have also found out, the saw needs Cool Tool. The bearings are lubricated with the saw water/oil. This is important. Cool Tool is inexpensive and a lot goes a long way. You will also need dop wax and dops. Metal dops work the best but wood dowels suffice. A shape template is a plus, and an aluminum pen for marking the shapes.
Post by sandsman1 on Jan 20, 2004 12:19:42 GMT -5
Post by docone31 on Jan 20, 2004 15:20:20 GMT -5
That should do. The frame looks like the same one. You should making cabs in no time.
Post by sandsman1 on Jan 20, 2004 20:37:41 GMT -5
i dont know how there gonna come out at first but i allways been a hands on learner i gotta doit to learn it so ill throw alot back into the tumbler im sure but ill get it hahaha im workin on gettin a better camera ill send in some pics of the first ones im sure every body needs a good laugh dont worry i can take a joke but no rollin on the floor hahahaha thanks again for all the info doc i prob would have two of everything by now --- john
i forgot anybody know where to get carbid wheels cheap i dont wanna start with diamond wheels and wreck um befor i fig how to doit ok seeya-s
Post by docone31 on Jan 21, 2004 17:43:46 GMT -5
You need corundum wheels, carbide ones are a pain in the neck. By the time you go through the ones that come with the machine, you will be ready for diamond. The diamond wheels are twice the cost of corundum but last ten times longer. You will have learned the touch by then.
Post by sandsman1 on Jan 21, 2004 18:36:35 GMT -5
hi doc im puttin this thing together in pieces im gonna buy a bare bones ba64 and add the rest myself i got a list of about 330.00 with out the two grinding wheels i im putting tw expandable wheels on the other side for belts and 1 polish disc for the right side does this sound about right from what i seen they want a few hundred mor for a all together unit so i fig id try and put one together from parts it seems to be alot cheaper that way i dont mind puttin the stuff on ya know . if you see me doin something wrong please yell at me hahahaha like i said im flyin blind just what i seen in pics is all i have to go by ok seeya and thanks for the brain power---john
Post by docone31 on Jan 21, 2004 18:50:19 GMT -5
You kinda lost me there, I went up to the site you posted and they no longer show the unit. I typed ba64 on search and it came up blank. If you are going to scratch build, why not just get an arbor and do it up? When I first started this, I used the unit you first showed with good results. By chance I ended up with the loretone combination unit. I had put my rubber drum on a grinding machine I got from Home Depot for 45$ and ran it dry. If you get the combination unit, you will only have room for two wheels. On mine, I run a 1 1/2 100 grit diamod and a rubber drum. I have found the disc just gets in the way and sometimes picks up grit. The trim saw is nice but it is annoying when all I am doing is cabbing. The biggest factor is speed. The final shaft must run at 1750 rpm. You can go 1-1 with the motor and arbor if you use ceiling fan rheostats of 600W. I prefer to reduce the motor speed at the shaft by going 1-1 1/2. Any internet lapidary source can provide the corundum wheels, and any hardware store can provide arbors. It is easier than most folks make it out to be. All I do is grind stones and polish them.
Post by sandsman1 on Jan 21, 2004 19:11:01 GMT -5
yea they just opened a new site and the pics arent there yet but its a lortone 4 wheel arbor without the wheels and motor goes for 165.00 - www.alpha-supply.com/catalog/pages.php?page=210 has two grinding wheels on one side and two barrels on the other well places for them i hafta buy them seperate or pay alot more for it allready put together im workin on disabilty pay some imm goin cheapest way out and buy the pieces it commin out alot cheaper there number is G1615 but pics not there yet ok seeya john
Post by docone31 on Jan 21, 2004 19:36:26 GMT -5
That works. If cost is an issue, as it is for most of us, you might consider a two station arbor. That would cost about 25$. The page you showed had drip wells for individual wheels. All the unit is, is an arbor with drip wells. The further from the main bearing point the more vibration is present. If it were me, I would get an old bedframe, an arbor, a motor from an appliance repair place, a piece of handi wood from Home Depot, and drill away. The bedframe I would cut to size. What size? Two feet by 18" would be over kill. The steel in the bedframe makes a great corner angle, and it can be used to fit the arbor. So you would have pieces of plywood, steel frame, machine screws, an arbor, drip pans, tool rest, and motor mount. A standard 36 grit is great for roughing in, 60 grit is great for taking off the coarse marks. Sanding belts do the rest. A leather buff does the polish. Before we had the lapidary giants over the internet, with their fancy paint, and great packaging, We little folks with a vision, made their own. Remember, all you are looking at is some bent sheet metal, stamped bearings, and a name. Skip the name, make it out of steel, and create some pieces of art. If you can see it, you can make it.
thewiz
"What good is money if you don't spend it"
Member since January 2004
Post by thewiz on Feb 18, 2004 23:03:44 GMT -5
john how did you make out with this looking to rough grind before 60/90
Post by sandsman1 on Feb 18, 2004 23:24:40 GMT -5
well im still thinkin bout what im gonna do will i was thinkin i bought a real cheap grinder for shaping rough think it was like 10.00 well im waitin for dhl to pickup and send back hahahaha one wheel wobbles think shaft is bent or berrings are bad it was listed as new hahaha so bewear the cheep deals pop allways told me if it sounds to good to be true it usually is hes prob lookin down laughin right now sayin told ya . i thought about it when i was orderin it but i kept sayin but it says new hahahaha yea right another lesson learned but im watchin for a break eather way a used arbor setup or pieces to start makin my own i did try some rock on the grinder and it does work but the rocks get real hot so i know im gonna have water with the next one even if i make it doc had the right idea with the bucket and the thruhull fitting and brass valve walla wet grinder hahahaha ok seeya john
thewiz
Post by thewiz on Feb 27, 2004 8:01:14 GMT -5
docone31 when you said "don't add anything to the water side it will foam up " do you mean don't even put water in it or add things to the water
Post by docone31 on Feb 27, 2004 18:25:15 GMT -5
I was referring to soaps, oils, etc. It just foams and foams and foams and foams. Goes everywhere and takes a couple of tanks to clean it out. Water is good.
