oneflesh
Member since December 2008
Post by oneflesh on Dec 28, 2008 11:58:25 GMT -5
We need to buy a tumbler for my 8 year old daughter. I (Santa) screwed up and got the wrong thing. I had originally thought I wanted to get her a vibratory tumbler just because of the time it saves. I'm open to suggestions, but I am leary about investing too much cash since she is only 8. Any feedback is great! Thanks! Brenna
Post by Bikerrandy on Dec 28, 2008 12:36:01 GMT -5
A vibratory tumbler would be great for her as long as she has some help. These things have to be monitored constantly. The biggest problem (I've seen this) with a rotary tumbler and an 8 year old is the weeks and sometimes months that it takes to properly do a good batch of stones. After the first week, they'll lose interest. At least with a vibe, they can physically see the progress, which will keep them interested. The downside is that they're noisey, but great if you have a garage to keep them in. For a vibratory tumbler (for an 8 year old), I'd probably go with the lot-o tumbler. For a rotary, maybe the Lortone 3a. Both of these tumblers will do smaller batches (like three pounds of rough). For bigger loads, the Thumblers UV-10 vibratory tumbler will do a ten pound batch, and the Lortone QT-6 rotary will do a 6 pound batch. Here's a website for you to check out, this guy's name is Shawn and he's the absolute biggest help when it comes to purchasing a tumbler.... great customer service!! www.therockshed.com/tumbler4.html
ejs
Member since July 2008
Post by ejs on Dec 28, 2008 17:36:53 GMT -5
I agree with all of what Randy said: Lot-o is a good place to start for a vibe, Lortone 3A for a rotary, and Rock Shed as a place to shop. My 5 year old son has one Lortone barrel that is his, and he is okay with the pace of the rotary process, especially since we do it together. Good luck and have fun!
docharber
Member since October 2008
Post by docharber on Dec 28, 2008 18:26:32 GMT -5
I would buy a larger rotary for initial grinding as this step is better done in a rotary and about as quickly accomplished. you can also buy preground tumbling material from some vendors for a small surcharge, with a higher end yield a most of the removed material comes off in the first grind. The Chicago Electric tumblers sold en masse on eBay would be great machines if they didn't come with lousy motors and belts. FOrtunateluy, you can replace these with lortone parts as they are such close knock-offs of the Lortones and build a respectable machine that's actually superior to off-the-shelf fLortones. Teh CE barrels are identical but thicker, and take Lortones lids, etc. The CE has an on-off switch and a heavier cord, with metal, not plastic, bearings. i rebuilt mine and it's done just great- for less than the cost of aNew Lortone. In any case, buy a bigger machine than you think you'll need, with multiple barrels as lapidary pursuits tend to mushroom. I'm building a 15 pounder and already have 2 6lb double barrels and a 12lb Portone, with a 5lb Raytech vibe running most of the time. you need less capacity in the vibes as they work much faster after the initial grind and use mucgh less grit. Have fun and Merry Chriostmas!
Mark H.
Post by Jack ( Yorkshire) on Dec 29, 2008 4:57:20 GMT -5
Hi Breena,
All good advice above
I would go for the for the rotary tumbler that gives you around 3 1/2 l to 4 lb and a Lot"O" to finish off
OR
BUT what a fantastic Idea from Mark H above on Buying Pre ground rocks ,Thats a good Idea with a child in mind
also you could use sea shore pebles (simular to pre ground )
I do a lot of sea shore stones straight into stage 2 in the Lot "O"
This would help the Cash flow so you only need only to buy a Lot "O"
If you want a more details on why a Lot"O" Tom (Connrock) and I had a exchange of letters discussing the whys and whereforths resulting in "Vibe Polishing recepie " e mail me john@matco.me.uk I would be delighted to send you a copy
Jack Yorkshire UK
ejs
Post by ejs on Dec 29, 2008 9:37:39 GMT -5
If cost is a major factor, then I think that going with a Lortone 3A might be the best solution. You'll only be able to do a single batch of 3 lb. at a time, and it will take a long time, but it may be the cheapest all-in-one unit and is easy for a child to run. Starting with river/iake/ocean-smoothed rocks is a great idea for cutting the time in half. And if you or your child gets into the hobby, then your Lortone will serve you well for a long time.
Good luck and let us know how it turns out!
