brent
Member since November 2008
Post by brent on Jan 18, 2009 17:54:44 GMT -5
I finally got my saw put together and running again. I changed the pullies to get the blade to fun faster and filled it with water for coolant. Pics to come soon.
Post by Jack, lapidaryrough on Jan 18, 2009 18:11:42 GMT -5
To run Faster ?, 3800 - 4500 SFM, newer blades 4500 - 5200 SFM.
Any faster you`l have your wallet open a lot more for new blades.
Lapidary Tools Lapidary Blades Cup Wheels Core Bits Hand Tools Polishing Supplies Accessories Library Tool Talk Blog Cut N' Strut Search Technical Library Lapidary Blade Speed Recommendations Blade MK-297 MK-301 MK-1000 MK-303
Recommended RPM Operating Range in Surface Feet Per Minute
3000 - 3500 3000 - 4500 4500 - 6000 4500 - 6000 Blade Diameter Approximate Arbor Shaft RPM Range 4" (102mm) 2860 - 3340 2860 - 4300 4300 - 5730 4300 - 5730 5" (127mm) 2290 - 2670 2290 - 3440 3440 - 4580 3440 - 4580 6" (152mm) 1910 - 2230 1910 - 2870 2870 - 3820 2870 - 3820 7" (178mm) 1640 - 1910 1640 - 2460 2460 - 3270 2460 - 3270 8" (203mm) 1430 - 1670 1430 - 2150 2150 - 2870 2150 - 2870 9" (229mm) 1270 - 1490 1270 - 1910 1910 - 2550 1910 - 2550 10" (254mm) 1150 - 1340 1150 - 1720 1720 - 2290 1720 - 2290 12" (305mm) 960 - 1110 960 - 1430 1430 - 1910 1430 - 1910 14" (356mm) 820 - 960 820 - 1230 1230 - 1640 1230 - 1640 16" (406mm) 720 - 840 720 - 1070 1070 - 1430 1070 - 1430 18" (457mm) 640 - 740 640 - 960 960 - 1270 960 - 1270 20" (508mm) 570 - 670 570 - 860 860 - 1150 860 - 1150 24" (610mm) 480 - 560 480 - 720 720 - 960 720 - 960 30" (762mm) 380 - 450 380 - 570 570 - 760 570 - 760 36" (914mm) 320 - 370 320 - 480 480 - 640 480 - 640
© 2008 MK Diamond Products, Inc. 1315 Storm Pkwy Torrance, CA 90501 Customer Service: (800) 421-5830 CustomerService@mkdiamond.com
Jack
brent
Post by brent on Jan 18, 2009 18:24:11 GMT -5
Thanx for the info. I'm not sure what the motor is rated for, but when I was cutting rock in the 7-8 hardnes range , and over a couple inches across , the saw would stall out. I increased the speed to 1:1. I seems to be working much better. I am guessing I am running in the 1700 r.p.m. range.
Post by Jack, lapidaryrough on Jan 18, 2009 19:16:16 GMT -5
for the 8 - 10'' blades that's fine.
for the arbor speeds i use on my saws 16, 18, 24s, i stick with the chart from MK-blades.
as for the feed speed stay in the range of 6 - 8 minutes to the inch. For saw`s over 16''.
If your hand feeding let the blade do the work.
Jack
