rcadamssr
Post by rcadamssr on Feb 3, 2009 8:29:55 GMT -5
How do you filter out the grinding residue from the oil? I am using equine mineral oil in my slab saw.
Post by Hard Rock Cafe on Feb 3, 2009 8:46:10 GMT -5
I haven't done it myself, although I plan to: put a paper grocery sack inside a 5 gallon bucket and fill it with the oil. The sack will allow the oil to pass through while capturing the mud.
I have rectangular buckets, so I thought I would drill holes in the bottom of one and put the paper sack in it, then put the bucket with holes inside another bucket. That way it's easy to reclaim the oil without having to take out the paper sack.
Hope that helps! I'm sure others have their own techniques, but this is the approach I've seen most often in the threads here.
Post by akansan on Feb 3, 2009 8:49:36 GMT -5
I use the two bucket method. One bucket - the straining bucket - has holes drilled in the bottom and sits inside the other bucket. I have about four screws screwed partway into the straining bucket about half-way down to allow a gap. I put two paper sacks in the top bucket, empty the saw into it, and then let it sit for a couple days. Sludge stays in top, clean oil in bottom.
Post by johnjsgems on Feb 3, 2009 10:05:21 GMT -5
What they said but 3 paper sacks . Depending on how much oil you have if you keep the sludge in a bucket any remaining oil will rise to the top and you can pour it off.
Mudshark
Diplomacy is the art of saying 'Nice doggie' until you can find a rock. Will Rogers
Member since December 2008
Post by Mudshark on Feb 3, 2009 11:40:57 GMT -5
I use the two bucket method also.But I'm curious to see if there are any other ways to filter it. Mike
mirkaba
Member since August 2006
Post by mirkaba on Feb 3, 2009 12:28:43 GMT -5
I use a piece of expanded metal that fits down into the top of the bucket. Only have one grocery here and no choice of paper bags. Just plastic! So I bought a bunch of old vacuum cleaner bags at Good Will to put the used oil in. Set it next to the wood stove for about a week or 2. And clean oil appears. Almost miraculously...................Bob
Post by deb193redux on Feb 4, 2009 1:59:51 GMT -5
some mineral oil is thicker and will filter slower; keeping it slightly warm will help speed things along
