Post by MyNewHobby on Feb 3, 2009 22:12:29 GMT -5
I just got done checking batch#4, stage 1 after three days and I really don't like what I see.
There are a couple of pieces that for some reason their faces are really pretty and their backs are in a raw state. But I think these two pieces would look really nice polished in a semi raw state. Is this usual or not? Maybe I will tumble them a bit more and see what happens.
There are only really 8-11 other of the pieces I would consider starting a new stage 1 tumble on.
I have a few fragments, chips, and jagged pieces. Should I continue and start them along with a new stage one tumble?
Also .... the water/sludge is brown .... dark brown .... is this usual?
So many questions .....
Help!
Terry664
Member since March 2005
Post by Terry664 on Feb 3, 2009 22:58:41 GMT -5
I have taken batches to pre-polish stage and didn't like them but they turned out OK. I think you are checking too soon and judging too early. Of course I don't know what hardness of stone you are tumbling, but if it is 6 or 7, I set up my tumble in 60/90 rough shut the lid and let run for 7 days, then check it, and go from there, if some stones are jagged and some round they will probably not be ready to move on at same time. Terry
Post by Sabre52 on Feb 3, 2009 23:03:16 GMT -5
*S* First off, sounds like you need a bit more patience. No reason to open up a batch in coarse grind at all till it's turned 7-8 days and then, for most quartz gems, you'll just rinse, recharge with grit, and set her to rolling again. Most quartz gems don't look like much until after at least three or four weeks in coarse with weekly recharges. Maybe less if you start with river rounded pebbles or beach stones where some shaping has been done by nature. As far as the color of your slurry goes, silicon carbide grit breaks down to a gray slurry but if there's lots of iron, hematite or manganese in the rocks, you're mixing in red or black oxides when you grind. Thus the different colors. Poppy jasper for instance, often contains lots of hematite ( an iron compound) so the slurry may be any shade of red or brown. Just take your time in coarse and go for nice rounded smooth shapes before moving stones on, make sure you tumble stones of similar hardness, and you'll nail down good batches all the time....Mel
Post by MyNewHobby on Feb 4, 2009 13:09:34 GMT -5
There's that word again ..... patience ..... ;D
Okay ....
Thanks again to all ... It is good reinforcement for me to slow down and get a hobby.
Oh wait .... this is my hobby .... DUH!
Guess I really do have to kick it up several notches on learning the grinder and flex shaft.
Post by Hard Rock Cafe on Feb 4, 2009 17:53:04 GMT -5
I've had to run some rocks for a month in coarse (with weekly recharges) before I was satisfied that they were ready for the next stage. I've got a number of rocks set aside to trim/grind before I tumble them again.
Yes, patience is the key.
And as Mel said, the slurry color changes depending on the rock. I was trimming some basalt matrix off of some Thomsonites and the mud coming off the Dremel was red (even though the basalt was black). Again, as Mel said, there was iron in it.
As far as disliking rocks, I've had some that I haven't liked even after they were polished. I also go geocaching and the ugly rocks frequently end up in caches for kids to find.
Post by LCARS on Feb 5, 2009 15:04:21 GMT -5
...As far as disliking rocks, I've had some that I haven't liked even after they were polished. I also go geocaching and the ugly rocks frequently end up in caches for kids to find. Chuck Tsk, tsk, tsk, using caches to offload your "ugly" rocks...
syfun
Post by syfun on Feb 5, 2009 15:30:55 GMT -5
As far as disliking rocks, I've had some that I haven't liked even after they were polished. I also go geocaching and the ugly rocks frequently end up in caches for kids to find. Chuck Hey, did I hear geocaching? I was wondering how many other RTH'ers were also cachers. My son has picked up polished rocks out of caches lots of times and he loves them. Now that we are into tumbling ourselves, we are planning on putting a cache out there that is nothing but polished rocks. Let others take what they want and we'll just keep filling it up. We are also planning on using some polished rocks (not just the ugly ones) as trade items. Back on topic: I have some plain rocks (I wouldn't say ugly, just not pretty, so plain) in my batches right now, I'm just curious as to how they will look when they come out. It also depends on what you are going to do with them. If you are going to make jewelry, then you probably want them all to be breathtaking. If you are going to fill a jar for display, then why not have a couple plain ones mixed in to make the others look that much better? Steve
Post by Hard Rock Cafe on Feb 5, 2009 18:56:30 GMT -5
Well, I guess I should qualify my earlier post by saying my "ugly" rocks for geocaching are Lake Superior Agates. They're just fractured or pitted, or both and they're on the small side. But still pretty, nonetheless.
Steve: I think the contrast would work nicely. If they're all nice, then there would be a lot of competition for your attention.
MikeS
Post by MikeS on Feb 7, 2009 12:18:02 GMT -5
Here is what I do to keep my paitence (or lack thereof in some cases) in check... I usually leave a coarse batch in the tumbler for 7-10 days, sometimes longer depending on my schedule. When it is time to recharge the grit, I inspect the rocks one by one, and I remove the ones I'm satisfied with, and replace them with new raw material. This way, I'm constantly removing and adding a portion of the material to the tumbler. I run my rotory pretty much 24-7. I have a constant supply of new material, however. I have literally buckets full of rocks waiting to be tumbled. I collect rocks pretty much year round. I work for the DOT, so I'm outdoors a lot, and much of my work places me in areas that have good material to collect. Most days I come home with a pocket full of agates, quartz, whatever.... I could stop collecting tomorrow, and it would still probably take me a few years to tumble all the rocks I currently have on hand... The only "drawback" to this is the fact that I'm constantly mixing different materials in the tumbler. But in all honesty, I haven't frequently run into problems doing this. There are notable exceptions to this...if I have a batch of very soft or easily damaged material, I tumble them seperately. I do however try to polish like materials together for the most part, when I remove material from the coarse grind I try to seperate them into batches of simialr material. But I have found as long as the all the material is somewhat similar in hardness, I can usually polish them together with no problem. As for pitted/fractured material, that tends to be a judgement call. With some of them you can only grind them down so far, the pits or fractures will never be completely removed. As long as there are no jagged or sharp edges on the material, and I can clean the pits and fractures out to prevent carryover, I have no problem with putting them in the next stage if I'm happy with the basic shape. Mike
ejs
Member since July 2008
Post by ejs on Feb 7, 2009 19:35:19 GMT -5
I own a geocache called the "Lapidary Mystery Cache". It leads you on a circumnavigation of a lake with four caches along the way. Each of those contains a coordinate to a final cache. That one is a fake rock hidden into an old rock wall. The final cache is filled with polished rocks as a reward for the finder. The hint for the final cache is "rocks in rock in rocks". :-)
I also have a fish bowl where I chuck rocks that just won't work, i.e. ones that are so deeply pitted or cracked that I know they will never polish properly. Fish tanks seem like a great place for unwanted rocks.
Post by LCARS on Feb 8, 2009 3:08:09 GMT -5
I used to have a Premium Member only cache called the "Concrete Quarry Geode Cache". (I made it PMO to keep it from being raided by unscrupulous freebie users) It was a rather evil hide as the co-ords would put you right in the middle of a pit quarry partly filled with crushed concrete bits and the cache was tucked under one of the small slab fragments amidst a zillion possible hidey holes. A few people with good GPSr's and/or good luck found it within 10 min but most needed half an hour or more of turning over rubble before stumbling onto it. One poor couple spent two hours on two attempts before finding it but hey, that's how she goes sometimes when yer a prospectin'. ;D The booty made it worth the hunt though, a 4"x8" Lock&Lock stuffed with all kinds of cool rocks and minerals, all packaged and labelled with BG info on each specimen including a generous quantity of nice quality loose tumbled stones in a ziploc with a note "Pick your favorite and keep it, I'll make more!" Honestly, I thought it would get "muggled" inside of a year but ultimately it's demise was met by heavy equipment that actually came to clear out the rubble after almost 8yrs that I can remember it being there. One day I was in the area & went to check on it and there was NOTHING and I mean NOTHING left in the quarry!! D'oh! I archived the listing and have yet to make a replacement somewhere else. I'm thinking of calling my next one "Rock-In The Cache Box" I'll just make it an all members listing, keep it stocked with polished rocks and imply a rock/mineral trading theme in the description and see what happens...
ejs
Post by ejs on Feb 8, 2009 7:58:51 GMT -5
Excellent ideas, LCARS! That sounds like a blast.
The final hiding containing for my mystery cache is fairly small, so I didn't want other people wasting the space with random leave-behinds. Thus, I made it a "take something leave nothing" cache that has to be restocked periodically. I live way out in the boonies, so only 9 people have found it during its first year. Come spring (which is late April around here), I'll check it for maintenance and restock.
Look up: GC1CEG5
Post by MyNewHobby on Feb 8, 2009 23:35:21 GMT -5
Okay .... dumb question .....
I have/had already started a batch/baggy of rocks that I felt would not even make it through the first grit and some raggedy partial polished stones.
Are these the caching/box mixes you are talking about?
They are OK rocks, but I would/will not use them ....
Again ..... my humble thanks Julie
Post by LCARS on Feb 9, 2009 1:05:32 GMT -5
Well, look at it this way, it's good to have some "practice rocks" for your first tumble or two that aren't all that spectacular so you can get the concepts down and won't have a freak out if they don't turn out right. Besides, that gives you time to hang out here and learn all kinds of killer pro tips while you hone your tumbling instincts for the more schmancy rocks you WILL be tumbling. :cheesy:
(hey there's new emots on the board, gotta use 'em right!) ;D
