rockin50
Rock Tumbling - It's worth the wait!
Member since February 2009
Post by rockin50 on Mar 5, 2009 19:25:15 GMT -5
Hello Again, I did a 5 day check on the rocks in my 3lb Thumbler during the pre-polish phase. I got to admit, when I took out a few and dried them off, they looked the same as when I put them in. No dull shine or any gloss at all. I even tried to damp rub a little final polish powder on them and got nothing. Should I be concerned? I'm gonna wait the full seven days and see what happens. Any suggestions? Thanks! Lou in NJ
NDK
Post by NDK on Mar 5, 2009 21:02:47 GMT -5
I read somewhere (I forget where, and if it's here I apologize) that you take a rock out of PP and dry it off, then rub it on your pants. If it shines up a little where you rubbed it, it's ready to polish.
Nate
Post by Jack ( Yorkshire) on Mar 6, 2009 4:40:44 GMT -5
Hi Rockin50,
Dont worry its a bit soon to get a polish I find try this method
I generally do a pre polish wash and burnish for 24 or 48 hours in Borax and ivory You should then see a dull shine on them ,
(this Method I find , 1 - cleans the stones . 2 - rubs the stones together and smooths them , 3 - washes the odd bit of grit out of a crack and keeps it mobile so it is washed away )
Then polish 2 weeks Rotary ( or 24 Hours Vibe = Lot"O")
Now if you dont get a shine --- Or preferably before you try See if there are any sharp corners on the rocks ANY chiped or broken
These will create havock and a dull finish take them ALL out before you start any polishing or even better still out from the 2 stage
Even if its your best piece that has just a little chip off the smallest corner !! Get it out
Im sure you will be pleased at the results you get following this method,
Jack Yorkshire UK
Post by frane on Mar 6, 2009 8:40:52 GMT -5
I agree with Jack. You may not see that shine until it is really clean and you buff it off with a cloth. Then move them forward to polish. Fran
rockin50
Post by rockin50 on Mar 6, 2009 19:05:34 GMT -5
You guys (and gals) are so nice, Thanks for the information. Jack thanks again for all the information. I am so happy I found this forum. I always loved turning these rocks into gems. Such a nice place to talk with others who share the same interests! Lou
ejs
Member since July 2008
Post by ejs on Mar 12, 2009 15:58:37 GMT -5
Rockin: I cannot tell by eye when my rocks are "done" with the pre-polish. If you take a small magnifier, like a jeweler's loupe, and view the rocks before and after pre-polish, you should notice that the scratches on the surface get smaller. But generally I don't see any real results until after polish - which is to say that I have to take it on faith that the pre-polish is doing something until after the final results at the end of polish. Good luck!
