walle
Member since February 2009
Post by walle on Mar 28, 2009 23:53:32 GMT -5
I have a vibe-10 that I use for just about all my rocks including sawed 2-3" slabs and get great results. I just bought a Covington 16" slab saw and was wondering if anyone has used a vibe 10 or 18 to polish larger slabs. Also, how about obsidian slabs, do they polish like other rocks such as agate, etc in a vibe? Thanks Mike (walle)
Post by Jack ( Yorkshire) on Mar 29, 2009 12:50:42 GMT -5
Hi Mike
Welcome to the board
I only have a small Vibe(Lot"O") and it makes a great job of slabs that go through the top as long as you add plenty of smaler stuff to carry the grit
Im sure others with more experiance will give you the advice you require
Jack Yorkshire UK
rockdewd
Member since October 2007
Post by rockdewd on Mar 29, 2009 13:34:18 GMT -5
The bowl for a ultravibe 18 lb is not that much larger than the uv 10. I'm able to polish up to a 4" slab in my uv 18.
Rick
