Post by stonesthatrock on Mar 31, 2009 15:19:54 GMT -5
i printed randys recipe for the vibe but in a lb. barrel how much grit do i use. I think his formula is for his 15 lb.
ty ralph and mary ann
fisherman510
Member since August 2008
Post by fisherman510 on Mar 31, 2009 16:30:44 GMT -5
My vibe is a 10 lb model. I use about 4 TBL of grit. If I was unsure, I would start out with a little bit and add till I liked the looks. I try to keep just a thin covering on my stones.
Bob
Post by Hard Rock Cafe on Mar 31, 2009 18:19:49 GMT -5
Is this the same recipe that Tom (Connrock) and Jack use?
I use 8 oz of 120/220 in my UV-18, 4 oz. of everything else.
Post by NatureNut on Mar 31, 2009 18:29:09 GMT -5
Hey guys, Randy's recipe is for a 10 lb. barrel (UV-10) and 4 Tblsp is good. I think it's a little bit different than Tom and Jack use, but I'm not sure. I've followed Randy's instructions and it's worked great. Jo
Post by Jack ( Yorkshire) on Apr 1, 2009 2:42:28 GMT -5
Hi Ralph and Mary Anne,
My Lot"O" is 3 1/2 lb
Here is a shortened version, contact Tom or Me (john@matco.me.uk) for the full recepie if you want
2nd stage is 6 flat tea spoons of 220 Grit
after that its only 1/2 a tea spoon of grit 500, 1000, tripoly.
Washing and changing after 220G and 500 G then I do a wash Burnishing /Borax stage then into 1000 G then add Tripoly to 1000G after 48 hrs (No washing)
24 to 36hrs later wash in warm water and Ivory
[glow=red,2,300]"After 24hours just see the high polish you get " Quote from Tom (Connrock)[/glow]
Hope this helps its a bit nearer to a 1lb machine than a 15lb machine
Just observe the rocks and the results you get
Jack Yorkshire UK
