mattrocks
Post by mattrocks on Apr 1, 2009 23:27:22 GMT -5
I started off using plastic pellets, and they seemed to work fine. They are kind of a pain. I just started with the ceramic pieces. Just wondering if one is better than the other, or in what case would you use one over the other.
Post by Hard Rock Cafe on Apr 2, 2009 7:17:48 GMT -5
Short answer: Use plastic in a rotary after the coarse grind; use ceramic in a vibe.
In a pinch, you can use ceramic in a rotary if you don't have the right mix of sizes, but it's much more expensive than small pieces of rock.
