thomtap
Member since December 2007
Post by thomtap on Apr 2, 2009 13:35:11 GMT -5
I have an idea for a tool for small round cabs. It probably has already been done before, but most everything has! Anyway, the idea is this. A cone shaped grinding and polishing tool. If my uploading skills work, my rough image of the device will show better than my words will. The small end would fit into a chuck, or onto a shaft. Grit would be applied to the inside of the cone, and the stone would be worked around inside the cone to produce a good high dome. Polish would continue with another such tool for the polishing compound. What do you think? Would this be hard to have made? Thom Tapp
drjo
Honduran Opal & DIY Nut
Post by drjo on Apr 3, 2009 9:15:03 GMT -5
