Dave Austin
Member since January 2008
Post by Dave Austin on Apr 11, 2009 17:59:36 GMT -5
Hi,
I slabed and shaped some labradorite today, this is the first time I have worked with this rock and I think I need to understand the best way to cut this material.
What I have realised is that a pendant will always hang in the vertical, but some of the slabs I have cut dont show the schiller in the vertical, you have to lay the slab horizontal to see the effect.
I would like to ask is there some technique for deciding the best way to slab a lump of this stuff so that the schiller is seen in the vertical.
Cheers
Dave
Post by Deleted on Apr 11, 2009 21:42:08 GMT -5
Dave Austin
Post by Dave Austin on Apr 12, 2009 2:30:57 GMT -5
Hi Weeshan,
thank you for these words of wisdom, I knew I must have been doning somthing wrong, now I know what it was.
Thanks again and have a nice day
Cheers
Dave
Dave Austin
Post by Dave Austin on Apr 26, 2009 4:40:23 GMT -5
Hi All, well its taken longer than I though but have finally got some decent cabs out of the Labradorite that I had initially cut when I first started this thread, too be honest I am thrilled with the outcome as this is my first attempt with Labradorite and I am hooked. I have learnt a lot while making this little lot, mainly dont be discouraged when you you initially inspect your slabs after cutting them, persevere through to the end. I have made a blog post and put pics at www.roughrocks.co.uk/?p=178Cheers to you all Dave
