Post by stonesthatrock on Apr 11, 2009 19:40:26 GMT -5
Post by 150FromFundy on Apr 11, 2009 20:14:26 GMT -5
Your slab 001 without the lightbox is white. The same slab with the lightbox is pink. Which one is true to the rock?
When I started using a lighbox, I had to adjust the White Balance on my camera so that the colors in the lightbox looked correct, especially the whites. There is a post on this on one of the forums.
Once you get the lightbox worked out, you will always use it. Like HD TV, it also magnifies every little flaw.
150FromFundy
Post by stonesthatrock on Apr 11, 2009 20:26:45 GMT -5
number one could be alittle whiter. I did adjust the balance and this was the best out of the 3 choices. the other 2 were yellow looking.
ty
Post by sitnwrap on Apr 11, 2009 21:16:42 GMT -5
I like your pics from the light box. They look clearer, brighter and more alive. I'm sure you will work out any kinks so congrats to the new improved pics.
10thumbs
I want to be reincarnated as a dog.
Post by 10thumbs on Apr 12, 2009 21:26:17 GMT -5
The picture in the light box is better. Its brighter and you have the camera perpendicular to the slab so I think the picture is much more clear. I can't tell if the white balance is off but obviously you don't want customers disappointed that the pink slab they purchased is actually white.
If you print off a standard test page from your color printer you could use that to adjust and validate your camera settings until you have something satisfactory.
You should probably put your rulers in your light box too. It's nice to know the scale without having to read the fine print.
Post by frane on Apr 12, 2009 21:44:11 GMT -5
I can see a lot more detail on the light box pics. Great job! Fran
Post by Bejewelme on Apr 12, 2009 21:46:55 GMT -5
MA: I am thinking I see pietersite up close and in focus? ? Good job, I couldn't figure my darn box out, so Tony has it, and I am having ok results with his vellum box!
Rogue Trader
"Don't cry because you are leaving, smile because you were there."
Member since December 2008
Post by Rogue Trader on Apr 13, 2009 13:05:18 GMT -5
Post by stonesthatrock on Apr 14, 2009 10:21:39 GMT -5
rogue? what are you smoking? ? lmao if its that good i want some.
Rogue Trader
Post by Rogue Trader on Apr 14, 2009 12:04:24 GMT -5
Post by stonesthatrock on Apr 14, 2009 12:36:03 GMT -5
ok your right i see them now lol
