Post by rockkitten on Nov 1, 2005 5:24:12 GMT -5
Where in the world do i find this stuff? I checked 4 stores and they don't carry it. It is a box of laundry detergent, isn't it??? has anyone used any other form of Ivory...bar soap, liquid laundry soap, liquid hand soap? and if so, how much compared to the flakes? I haven't given up yet.
gemmaster
Member since July 2005
Post by gemmaster on Nov 1, 2005 6:13:54 GMT -5
walmart, the biggest, most aggregious,agressive babylonian prositittute of retailing doesnot carry it here in central georgia ,nor do several stores around. the only advantage if you can find it is that it contains only soap, not a chemical industry list of ingredients , none of which are of use to a tumbler.in tumbling the non-bleach type detergents are fine ,but i slab a lot and the laundry soaps leave sl;imy ,sticky annoying residue on your hands, wish i had a solution shurely proctor/gamble still make ivory , but i am beginning to wonder. good luck . gemmaster
Post by Tweetiepy on Nov 1, 2005 8:56:01 GMT -5
I just take an ivory bar & grate it on the box grater you should be able to find it in the laundry section
Post by jdennis on Nov 1, 2005 9:37:53 GMT -5
what do use the soap for? new to tumbeling so i have no clue lol
Post by rockds on Nov 1, 2005 9:55:06 GMT -5
As some one who knows, Ivory flakes are seldom made and when they are, they are usually made over seas or for export - althought they can still be found usually in rual areas. if interested i could go on and on about soap but i will not bore you with that here. i use borax but if you must use ivory save yourself a lot of trouble and buy a bar a shave it up yourself.
Post by stefan on Nov 1, 2005 9:58:03 GMT -5
Or look for a product called DEFT- it is made by Ivory as a Dollar store special (same as the original Ivory Flakes!)
Post by Cher on Nov 1, 2005 10:20:05 GMT -5
Get some 20 Mule Team Borax. It's in the laundry section and I know KMart carries it, haven't looked anywhere else. Don't need to worry about cutting up the ivory soap then.
It is used with hot water to wash the rocks, pellets and barrel when a load finishes before moving the rocks on to the next stage. Also, after the final polish to bring out the shine and remove any residue from tumbling.
Post by creativeminded on Nov 1, 2005 10:33:11 GMT -5
I use Borax, it is hard to find but you should be able to find it at Wal-mart, that is where I found mine. I tried using ground up Ivory bar soap and when I opened my tumbler there was clumps of ivory soap. Tami
rollingstone
Member since July 2009
Post by rollingstone on Nov 1, 2005 13:13:30 GMT -5
I guess I should put my two cents in here, since I am one of the minority using Ivory. The Ivory soap flakes stopped being made over a decade ago. I was fortunate to have a large box of them, but that ran out about a year ago. It was a powdered laundry soap, about the consistency of something like Tide, but it had no harsh chemicals and was recommended for babies laundry. That's the problem with replacing it with regular laundry detergent, the chemicals (bleach, etc) can be hard on your barrels.
As a replacement, I now use Ivory bar soap, pared with a knife to give as fine flakes as I can get. I tried grating it once, but it just mucks up into a mat. Paring it with a knife, you can get either fine curls, or sometimes if the bar is especially dry it will break into powder. Anyway, use about half as much as was recommended for the powdered soap, since the shaved stuff is chunkier and denser.
Someone did a survey of whether people on the board use Ivory or Borax, and borax was by far the most popular. But I'm sticking with Ivory, as it has always done a great job for me, even cleaned up one batch to a mirror shine after it came out of polish all covered in scum and looking like it was going to be a flop.
Post by Tweetiepy on Nov 1, 2005 13:19:18 GMT -5
Rolling: do you use hot water with your Ivory flakes? I've always put coldish water in my barrels. I too use Ivory, I grate mine on the smallest grater, they stay nice & fluffy - too bad the smell doesn't agree with me Bleurk!
Post by rockkitten on Nov 1, 2005 14:52:30 GMT -5
i DID BUY THE BORAX, BUT I COULD HAVE SWORN THAT SOMEWHERE ON HERE I READ THAT SOMEONE USES BORAX AND Ivory! I've copied tons of info so will have to look it up. thanks for the info, you saved me alot of searching. if i do use it, i'll get a bar.
Post by rockds on Nov 1, 2005 16:24:03 GMT -5
if you use dove with 1/4 cup moisturizing cream your rocks will come out younger looking and all soft to the touch
rollingstone
Post by rollingstone on Nov 2, 2005 2:17:47 GMT -5
Rolling: do you use hot water with your Ivory flakes? I've always put coldish water in my barrels. I too use Ivory, I grate mine on the smallest grater, they stay nice & fluffy - too bad the smell doesn't agree with me Bleurk! Tweet, I use room-temperature water. My thinking is that if I used cold water then there would be some expansion pressure as it warmed to room temperature in the barrel, and that might break the seal on the barrel. With hot water, contraction of the hot water/vapour might have a similar but opposite effect as the hot water in the barrel came to room temperature. I have no idea if either the expansion or contraction would be enough to break the seal, but I just go with approximately room-temperature water to avoid the problem altogether.
littlejimie
A rolling stone gathers no moss
Post by littlejimie on Nov 2, 2005 12:50:05 GMT -5
I use shaved Ivory bar soap in all stages except coarse. For burnishing, I use Ivory soap and Borax together and run for 24 hrs with plastic pellets.
MichiganRocks
"I wasn't born to follow."
Member since April 2007
Post by MichiganRocks on Nov 2, 2005 17:37:48 GMT -5
There's always a lot of discussion about "Ivory Flakes". By now, I hope that all know that "Ivory Flakes" is now longer marketed in the U.S.A. It should also be understood that "Ivory Flakes" was a soap, not a detergent. All of the modern products are detergents and not soaps. The difference is as follows:
Soaps are made of materials found in nature. Detergents are synthetic (although some of the ingredients are natural); they were developed during World War II when oils to make soap were scarce.
There is little doubt that soap is better for your health and the environment than detergents. Detergents are very toxic to fish and wildlife. Nonetheless, a big drawback of washing with soap is that the minerals in water react with those in soap, leaving an insoluble film. This can turn clothes grayish, and the film can leave a residue (such as is found on shower stalls, for example).
Detergents react less to minerals in water and for all practical purposes are the product of choice for laundry, unless you have very soft water. Those of you with hard water—which has a high mineral content—already know about this, I am sure. If you choose to wash your clothes with a detergent—or the dishes, or some of my recipes asking for a biodegradable soap or detergent—you can ensure the least possible damage to the environment by selecting the most biodegradable products.
Health food stores have a number of brands of detergent that are made with renewable materials instead of petroleum-based ingredients, and with natural essential oil fragrance and no dyes. They also sell liquid vegetable-oil soaps called castile soap.
Borax does offer a lot of the benefits of soap without the harsh attributes of detergent. We all do still have the choice of making our own soap (Beverley Hillbillies)!
Ron
proudpapa56
Member since December 2004
Post by proudpapa56 on Nov 2, 2005 19:50:21 GMT -5
Careful when using Deft. Read labels. Depending on where it's made Deft can be chock full of detergent. My ten year old loves it when he has to grate a bar of Ivory.
carolelgin
BlueBelle
Member since October 2005
Post by carolelgin on Nov 3, 2005 19:28:41 GMT -5
carolelgin
BlueBelle
Post by carolelgin on Nov 3, 2005 19:29:25 GMT -5
I wonder if freezing the bar of ivory and then using a grater would work?
Will try it and let y'all know.
Post by Fossilman on Mar 13, 2015 12:33:46 GMT -5
This needs to be "bumped" up.................Great idea.......
Post by Fossilman on Mar 13, 2015 19:17:12 GMT -5
I just run some Ivory soap in my tumbler,with the Montana agates-just cleaned them up an hour ago..Waiting for them to dry now....
