Saskrock
Member since October 2007
Post by Saskrock on May 7, 2009 1:11:39 GMT -5
I have a 10" frantom saw that I am using mineral oil in. Works great but after a cut unless I wait a long time after turning it off before opening the lid I get a cloud of oil mist coming out. Any tricks for a new slabber on how to stop this? Or do I have to live with it?
Post by rockmanken on May 7, 2009 6:42:49 GMT -5
Live with it. At least you have a cover. I have a Lortone drop saw and you can't cover it. ken
Post by Hard Rock Cafe on May 7, 2009 6:46:47 GMT -5
Try Bardahl "No Smoke" or STP "Smoke Treatment". I'm not sure what's available in Canada, but these are found in auto parts stores and Walmart. There's probably something similar. It's about the consistency of honey.
You only need about an ounce or less in a 10" saw.
Mudshark
Diplomacy is the art of saying 'Nice doggie' until you can find a rock. Will Rogers
Member since December 2008
Post by Mudshark on May 7, 2009 15:52:34 GMT -5
I usually get what you described when the oil gets a little low or gunked up with rock dust.The blade should be covered about 1/4 inch in oil with the saw off.I like to use a little bit more than that and add oil as I go along.10 inch saws dont hold much oil and need to be drained and cleaned frequently.The products Chuck wrote about should work fine also,if not available in your area you can get them online. Mike
Saskrock
Post by Saskrock on May 7, 2009 22:14:45 GMT -5
I found the Bardahl "No Smoke" at Canadian Tire. I can`t believe what a difference that stuff makes. There was no noticable mist after adding it. Thanks for the advice Chuck.
agatemaggot
Member since August 2006
Post by agatemaggot on May 8, 2009 5:43:54 GMT -5
No Smoke is great stuff, breathing that oil mist is NOT good business. Don't know what's in that stuff but it works like magic !
Post by Hard Rock Cafe on May 8, 2009 5:57:08 GMT -5
You're welcome Scott!
I'm glad it helped. I was just passing along something that I learned here and worked for me.
drjo
Honduran Opal & DIY Nut
Post by drjo on May 8, 2009 8:15:55 GMT -5
I thought rockbottom had a pick of a filter for oil mist but I can't locate it now. Very simple, just a muffin fan,bucket with lid, some filter media for the oil to collect on and some larger vacuum style hose.
Dr Joe
